Georgia Mike Posted March 9 Share Posted March 9 Had to go over and winterize my bus again and while I was in the water bay area I found this switch and was wondering what it’s for. 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted March 9 Share Posted March 9 Where is it exactly located in the Service Bay? Link to comment Share on other sites More sharing options...
mikeb64 Posted March 9 Share Posted March 9 If I am looking at it correctly it should be for your water hose reel the switch on the bottom is actually a reset for the fuse The water hose reel I believe is manually out electric in hope this helps Link to comment Share on other sites More sharing options...
Georgia Mike Posted March 9 Author Share Posted March 9 You have to open the stainless door and its right in front of the hose reel. I pressed it and nothing happened from what i can tell. Thanks Mike but its not that. I have switches in front of this area like a false wall that has the power cord reel for electric, water, sani flush, water pump and something else i forget. This switch is by itself and I traced the wires into a bundle. Anyways, just thought someone might know its bugging me. Link to comment Share on other sites More sharing options...
det944 Posted March 9 Share Posted March 9 That's the circuit protection for your power hose reel. The switch on the false wall with the other switches retracts the hose when pressed. The switch pictured is a double action circuit breaker that will trip if too much current is detected during retraction. The small switch marked 4 amp will have a white band exposed when tripped. The hose reel will not retract. I think the small switch needs pressed then the larger one to reset the circuit. Then the hose retract switch on the front switch panel should retract the hose. I usually open the panel so I can guide the hose on to the reel so it doesn't tangle causing binding , tripping the circuit. Link to comment Share on other sites More sharing options...
Georgia Mike Posted March 10 Author Share Posted March 10 Thanks Dan for the information. I will know where to look when my power reel stops working. I looked in the Monaco owners manual but couldn’t find any information about it. Link to comment Share on other sites More sharing options...
det944 Posted March 10 Share Posted March 10 Yes Sir, hope it helps.Learning as I go. The previous owner gave me a heads up on the circuit protection. He was really good at explaining things as we launched into our new adventures. Link to comment Share on other sites More sharing options...
Dr4Film Posted March 15 Share Posted March 15 Mike, I have not been able to find the exact same switch in my service bay. I would sure like to know where MINE is located in case I have to reset it. Anybody have a clue where it might be in my coach? Link to comment Share on other sites More sharing options...
Georgia Mike Posted March 15 Author Share Posted March 15 Richard, mine was inside that stainless service door near the hose reel. I would think it would be out in open and accessible but maybe they hid it in an odd place you never know. Link to comment Share on other sites More sharing options...
