Mike T Phillips Posted March 24, 2022 Share Posted March 24, 2022 The electronic water input valve appears to be malfunctioning. When I push the switch up to fill the water tank it continues filling in the water right after the tank is finished it runs out the overflow pipe beside the passenger wheel. If you push it down all the way so you were only on city water and the water tank is full it overflows completely and runs all the time does anybody know the valve number so I can order a new valve without having to get into it and tear it all apart. Link to comment Share on other sites More sharing options...
TigerMar Posted March 24, 2022 Share Posted March 24, 2022 Hi Mike, I have a 2008 Monaco Dynasty. The valve for mine is a 1/2 inch 8210G94 2way NC 12 VDC 40 PSI Asco valve. I have had to replace it. 1/2 8210G94 BRS 2-WAY NC 12 VDC 40 | Galloup On mine it is located behind the hose and electric reels accessed through sliding doors in the basement storage walls. Pretty easy to change out. Gary Link to comment Share on other sites More sharing options...
DrDon4u Posted March 25, 2022 Share Posted March 25, 2022 I just replaced mine a few days ago. Same thing happen to me. I needed one right away because we had no water coming into the coach. ASCO 8210G094 12DC found GRAINGER had one in stock for $160. So I drove over and got it, put it in. All fixed, the wife is HAPPY. Link to comment Share on other sites More sharing options...
amphi_sc Posted March 25, 2022 Share Posted March 25, 2022 For what its worth, I replaced mine with; https://www.ebay.com/itm/121358112687 I liked the specs better. Link to comment Share on other sites More sharing options...
