Timothy Posted March 30 Share Posted March 30 Does any one know where to purchase the rubber seal for the storage compartment doors Link to comment Share on other sites More sharing options...
David White Posted March 30 Share Posted March 30 You likely will need to match the profile with a company, such as Steele Rubber (steelerubber.com). There are a few other that offer assorted replacement rubber seals. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 30 Share Posted March 30 Tim, I had a problem with the gasket on the bottom edge tearing from sliding objects over it when taking them in or out. I couldn't find the same pattern. Staring at it one day I noticed that the top gasket was like new. (bright light bulb) I rotated the gasket, put the top on the bottom and vice versa. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
1nolaguy Posted March 30 Share Posted March 30 1 hour ago, Timothy said: Does any one know where to purchase the rubber seal for the storage compartment doors Steele Rubber products and AP Products have the friction fit type (as use on my 2005 Safari Cheetah 40 DST, yours may be similar. Also try Uni-Grip.com. Talin RV had sourced my slide seals there. Link to comment Share on other sites More sharing options...
LakeBob Posted March 30 Share Posted March 30 Recently replaced one compartment seal with the below from Steele, perfect match for the existing, rusted seal. Gave them a call and they were very easy to work with and made sure that it shipped the same day. http://d163axztg8am2h.cloudfront.net/static/img/66/08/c587474a9817ff908b6a2cf112c5.jpg Thin Side Lip Push-On Seal Part #: 70-3801-277 Description: Easy to install push-on seal with a flexible metal core fit flanges 1/16" to 1/8". Available by the foot. Link to comment Share on other sites More sharing options...
Timothy Posted March 31 Author Share Posted March 31 Thank you all for the Leeds and ideas. Mine is damaged at the top edge and is no longer serviceable for any part of the compartment so I can not flip it. I will update after I research and order the most applicable seal. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted March 31 Share Posted March 31 You need to download the parts list to your device. It has a lot of parts listed for your coach. The parts list can be found in the download section of the group site. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Paul A. Posted March 31 Share Posted March 31 21 hours ago, Timothy said: Does any one know where to purchase the rubber seal for the storage compartment doors https://www.steelerubber.com/ They will send samples for you to try/match. Link to comment Share on other sites More sharing options...
Timothy Posted March 31 Author Share Posted March 31 Thank you Paul Link to comment Share on other sites More sharing options...
