Jack omartin Posted April 27, 2022 Share Posted April 27, 2022 While underway my cruise control disengaged & I tried to reset it but it wouldn't & saw a Amber CEL on so but no performance issues as I looked at my TRIPTEK & all looked good too. I stopped for a fuel up & looked everything over & I restarted & no CEL but Cruise wouldn't turn on..so I recycled the chassis batteries got back on the road & the cruise turned on & set..but only lasted about 20 miles or so & the Amber CEL came back on but I drove another 1000 miles home with no issues. I purchased a Scangauge-D & got a ID 151...FM 14...CNT 1 fault code & they use Big Diesel code system says it's ATC Control Status Identifies the current state of the ATC (automatic traction control) control functions, signals, lamp and switch. I went to my Cummins Quickserve & it converts the 151 to a SPN 110...FMI...Lamp Color Description Red..Engine (Coolant Temperature Sensor)- Data Valid But Above Normal Operating Range - Most Severe Level...Reason: Coolant temperature signal indicates coolant temperature has exceeded the engine protection limit.None of this happened with the Cummins SPN 110. I called Spartan on the ATC code since I'm not aware the coach even has an ATC system just ABS & he confirmed it doesn't & told me to find the Bussman Box & pull the ABS fuses & ee if that helps...I did...& it didn't. I cleared the code but no cruise..BTW the PTO using the Cruise controls works fine! Frustrated I installed a new Coolant Temp Sensor anyway & no change. Just to test the that sensor & circuit I left the connector off & run the engine & the dash temp gauge was swinging up & down & the CEL was on..scangauge said code SPN 110 as it should...then reconnected it & all's back to normal CEL went off & cleared the code. Which brings me back to the SPN 151 code. I'm tryin to get to the ECM to pull & inspect the connecters for any issues but I can't get to it. I've seen where owner was chasing down a similar issue for weeks from the front on the coach to the back inspecting every connector & finally got to the ECM & after taking the 2 connectors out & seeing some corrosion on them cleaned them up & low & behold No more CEL..He had an older coach like mine. So I'm at 3 weeks now digging for info. Any insight to this my right foot & I would appreciate it. 2004 American Eaglecummins 400 ISLSpartan MM chassis Link to comment Share on other sites More sharing options...
cbr046 Posted April 28, 2022 Share Posted April 28, 2022 (edited) When this happened to me (2003 ISC engine) it started out with ATC light coming on under load with cruise control downshifting the transmission. ATC light goes off with a lift of the throttle. The conditions kept getting worse over (maybe) 2,000 miles until I was getting loss of boost, loss of power and could barely make it up modest hills. Turned out the primary fuel filter was clogging and the ATC light and transmission downshift on cruise control were the first indicators. Some Cummins software engineer wrote this into the ECM software without telling anybody. Filter is easy and relatively low cost to change. Try it. Don't forget to pre-fill the outer holes of the filter and, of course, do the ignition on-wait 30 seconds-ignition off dance for 4x before hitting the starter. Your CAPS pump will thank you. - bob Edited April 28, 2022 by cbr046 Link to comment Share on other sites More sharing options...
Jack omartin Posted April 28, 2022 Author Share Posted April 28, 2022 Thanks for the reply Bob...in the the beginning of this chase I did hear this & changed out my filter..even though I didn't have ATC on the coach as I stated & it didn't changed the issue. It has to be something relatively simply since I absolutely no performance issues driving that 1000 miles home. I sure it's not a Smart wheel master control problem or clock spring since the amber CEL disengaged the Cruise while underway. I'm trying to avoid going to Cummins for the obvious..cost! I gotta tell you I'm disappointed with both Spartan & Cummins for they're lack of help in giving them a ton of info on this problem. They're kinda pointing at each other saying it's chassis issues the other saying it's an engine sensor issue. It shouldn't be this hard. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted April 28, 2022 Share Posted April 28, 2022 FWIW, this is a Monaco Coach site, not a American Eagle site. Good luck in finding a solution to your issue. Link to comment Share on other sites More sharing options...
Jack omartin Posted April 28, 2022 Author Share Posted April 28, 2022 Yes I did see that..I saw a post on the IRV2 site with Bill's name & this site in regards to a member asking for some help with his "Cruise Control" & Bill was referred to as an EXPERT on it. Link to comment Share on other sites More sharing options...
Frank McElroy Posted May 2, 2022 Share Posted May 2, 2022 On 4/27/2022 at 7:49 PM, Jack omartin said: While underway my cruise control disengaged & I tried to reset it but it wouldn't & saw a Amber CEL on so but no performance issues as I looked at my TRIPTEK & all looked good too. I stopped for a fuel up & looked everything over & I restarted & no CEL but Cruise wouldn't turn on..so I recycled the chassis batteries got back on the road & the cruise turned on & set..but only lasted about 20 miles or so & the Amber CEL came back on but I drove another 1000 miles home with no issues. I purchased a Scangauge-D & got a ID 151...FM 14...CNT 1 fault code & they use Big Diesel code system says it's ATC Control Status Identifies the current state of the ATC (automatic traction control) control functions, signals, lamp and switch. I went to my Cummins Quickserve & it converts the 151 to a SPN 110...FMI...Lamp Color Description Red..Engine (Coolant Temperature Sensor)- Data Valid But Above Normal Operating Range - Most Severe Level...Reason: Coolant temperature signal indicates coolant temperature has exceeded the engine protection limit.None of this happened with the Cummins SPN 110. I called Spartan on the ATC code since I'm not aware the coach even has an ATC system just ABS & he confirmed it doesn't & told me to find the Bussman Box & pull the ABS fuses & ee if that helps...I did...& it didn't. I cleared the code but no cruise..BTW the PTO using the Cruise controls works fine! Frustrated I installed a new Coolant Temp Sensor anyway & no change. Just to test the that sensor & circuit I left the connector off & run the engine & the dash temp gauge was swinging up & down & the CEL was on..scangauge said code SPN 110 as it should...then reconnected it & all's back to normal CEL went off & cleared the code. Which brings me back to the SPN 151 code. I'm tryin to get to the ECM to pull & inspect the connecters for any issues but I can't get to it. I've seen where owner was chasing down a similar issue for weeks from the front on the coach to the back inspecting every connector & finally got to the ECM & after taking the 2 connectors out & seeing some corrosion on them cleaned them up & low & behold No more CEL..He had an older coach like mine. So I'm at 3 weeks now digging for info. Any insight to this my right foot & I would appreciate it. 2004 American Eaglecummins 400 ISLSpartan MM chassis Understanding how the engine and transmission systems communicate with each other can help in diagnosing a problem. When the transmission detects that the engine is not producing the anticipated amount of power based on the throttle position, engine RPM and road speed the transmission will disable the automatic traction control. When this happens, the first thing you should do is to change the fuel filters. One of the first signs you will see when fuel filters are starting to plug is an ATC light. But in certain conditions, with the CEL on, the cruise control might also be disabled by the engine ECM. You mentioned that you are getting an error code for high engine coolant temperature. At high engine temperatures, the engine will derate and shut off the cruise control. If your dash temperature gauge is normal and your transmission temperature is normal, I'd look at the engine coolant temperature sensor. Keep in mind you might have one coolant temperature sensor for the dash gauges and another one for the engine ECM. Link to comment Share on other sites More sharing options...
