cbr046 Posted April 30, 2022 Share Posted April 30, 2022 Ordered parts in Feb from Newark Electronics and they finally showed up, just in time for Summer 😉 The problem with the wet bay heater is a single under-spec'd thermal fuse controlling a 300W heater element. 300W/12V=25A. Maybe the OEM fuse was 25A . . . . or 30A, but those aren't available anymore. The largest thermal fuse available is 20A / 184C. This value is way under-spec'd. Still, the 20A / 184C fuse will last a little while . . . a few minutes? an hour? a night maybe? My solution was to split the top and bottom elements into 2 banks, one with 2 elements the other with 3 elements with a fuse for each bank. The top bank will draw 120W, or 10A. The bottom bank will draw 180W, or 15A. This is well below the rating of the available 20A / 184C fuse. The top and bottom "banks" no longer have the same mechanical support. I thought about adding a dab of epoxy to bridge the gap . . . . . but didn't. I crimped two 20A / 184C thermal fuses to the supply with one fuse going to the bottom bank and the other to the top bank. BTW, the crimps are ugly because I used vice grips to clamp them on. BIG vice grips. The recommended terminal crimp is very heavy duty, rated for 343C. Here's the Newark part numbers 20A / 184C thermal fuse - https://www.newark.com/thermodisc/g5a01184c/fuse-thermal-184-c-20a-250vac/dp/39T4439 - $2.37 each Terminal Crimp (Parallel Splice) - https://www.newark.com/amp-te-connectivity/323754/terminal-parallel-splice-crimp/dp/50F3313 - $0.875 each By shorting the snap-disc in the wet bay I was able to test the repair and see all 5 elements glow a nice orange, but I guess I won't know how good the fix really is until December. I am VERY optimistic! - bob  1 Link to comment Share on other sites More sharing options...
CLIFF918 Posted April 30, 2022 Share Posted April 30, 2022 Hey Bob here is another option for the future. Amazon has an assortment of thermal fuses available: https://www.amazon.com/Hilitchi-Circuit-Temperature-Thermal-Assortment/dp/B0719DHV9P/ref=sxin_25_ac_d_rm?ac_md=0-0-dGhlcm1hbCBmdXNl-ac_d_rm_rm_rm&crid=LWNW4GJ7XSZ&cv_ct_cx=thermal+fuse&keywords=thermal+fuse&pd_rd_i=B0719DHV9P&pd_rd_r=1ba352d1-bd63-4517-8dc0-ecabb95453d7&pd_rd_w=G3OPK&pd_rd_wg=wXj3n&pf_rd_p=7de181be-756e-4582-93e5-e9bf36281b5f&pf_rd_r=0BFXJDKTXRQJDMT40D29&psc=1&qid=1651310873&sprefix=Thermal+fuse%2Caps%2C130&sr=1-1-7d9bfb42-6e38-4445-b604-42cab39e191b 1 Link to comment Share on other sites More sharing options...
cbr046 Posted April 30, 2022 Author Share Posted April 30, 2022 2 hours ago, CLIFF918 said: Hey Bob here is another option for the future. Amazon has an assortment of thermal fuses available: https://www.amazon.com/Hilitchi-Circuit-Temperature-Thermal-Assortment/dp/B0719DHV9P Those are all 10A fuses and would blow in a millisecond. But that's the trick - gotta have current and temp ratings which I discovered very hard to find . . . . . And no, you can't put two 10A fuses in parallel! - bob Link to comment Share on other sites More sharing options...
jim.hamblin Posted May 1, 2022 Share Posted May 1, 2022 I’ve got several extras from when I repaired mine, I’d have to look to see what rating they are. I got the part no. from the original poster on doing the repair here on this site. If anyone need one or more and I’ll send them. jim Link to comment Share on other sites More sharing options...
jacwjames Posted May 1, 2022 Share Posted May 1, 2022 Any reason you couldn't mount a self-resetting circuit breaker on the outside. I installed a small 120 volt Broan heater in the master bath for my wife, I even put a timer in the circuit knowing she'd forget to turn it off.  She has a tendency to run a lot. Last month she said "the heater quit working". So I tore into it and found that they installed a thermo disc in the heater but it was not self resetting, you have to physically press a small button. Not a big deal now that I know it's there. Link to comment Share on other sites More sharing options...
