sg47619 Posted May 21, 2022 Share Posted May 21, 2022 I have a 2001 Monaco Dynasty , has anyone one taken the plastic gear off the topper tube to change the fabric. Thanks in advance Steve. Link to comment Share on other sites More sharing options...
Wheelsnkeels Posted May 22, 2022 Share Posted May 22, 2022 Hi Steve We also have a 2001 Dynasty, yes I have removed them by drilling out the rivets. After replacement installation of new rivets. Link to comment Share on other sites More sharing options...
sg47619 Posted May 22, 2022 Author Share Posted May 22, 2022 Thank you, that’s what I thought but want to here from some one that had done it. Thanks again. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 23, 2022 Share Posted May 23, 2022 Easey peasy, done it many times to replace broken straps. I always choose the non-spring end when changing straps. BTW (by the way), the omega awnings will work with springs in either end. Years ago, I needed a new spring in my large roadside slide on the Windsor. The service tech from Shade-Pro in San Diego brought a lefthand spring instead of a righthand spring. He just installed it in the other end and works great. The bedroom slide still has the spring in the right end. Link to comment Share on other sites More sharing options...
veraken Posted May 24, 2022 Share Posted May 24, 2022 Attached is a copy of the Installation and Service manual for the Omega II which may help you Carefree Omega II Install & Service Manual.pdf Link to comment Share on other sites More sharing options...
