Greg Carter Posted May 21, 2022 Share Posted May 21, 2022 So perhaps a silly question but someone will know I'm sure.While I was changing the SS exhaust tip the other day I noticed that the A/C condenser isn't installed on the RH side even though there is a Fan mounted and hooked up although I found in was seized up. This is on the 97 Dynasty that my Dad bought new (build date around Aug 96 but registered on all papers as a 97).So checked the 95 Dynasty that I bought in 2011 and sure enough there it is on the same RH side. So perhaps it’s in another location or part on the installation up front.I have checked wiring diagrams that I had and compared them to those on Monacoers and interesting is that up to somewhere in 96 they show the A/C Condenser Fan wiring and then a 97 drawing ( with a dated Aug 95?) that same fan assembly disappeared with no mention from that drawing.So I have to assume that Sometime in 96 Coburg stopped putting in a Condenser ? But they put the Fan Assembly in place and wired up.I'm sure it was running before it seized up.Sorry for the long story but hopefully someone might know the answer.Thanks for any information.Cheers Link to comment Share on other sites More sharing options...
Tom Whitlow Posted May 22, 2022 Share Posted May 22, 2022 My 96 HR Endeavor Diesel also had the rear pax side vent and electric fan. I think it had the A/C condenser there. When the fan seized, the dash A/C quit blowing cold until it was replaced. PIA to replace that fan. Link to comment Share on other sites More sharing options...
dl_racing427 Posted May 24, 2022 Share Posted May 24, 2022 My 1993 Dynasty has the A/C Condenser and fans on the passenger side as well. Curious that they'd install the fans when the condenser isn't located there. LOL Link to comment Share on other sites More sharing options...
CTerry Posted May 24, 2022 Share Posted May 24, 2022 On my 2003 Beaver the condenser and fan is located right behind the front step. Link to comment Share on other sites More sharing options...
