sg47619 Posted July 8, 2022 Share Posted July 8, 2022 Looking for the water pump switch for my 01 Monaco Dynasty Jack 38. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 8, 2022 Share Posted July 8, 2022 (edited) One other member had just asked the very same question not too long ago. Is it ON/OFF/ON or is it a Momentary Switch? I also found the post that I referenced above. Edited July 8, 2022 by Dr4Film Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 8, 2022 Share Posted July 8, 2022 53 minutes ago, Dr4Film said: One other member had just asked the very same question not too long ago. Is it ON/OFF/ON or is it a Momentary Switch? I also found the post that I referenced above. Richard is correct, I believe. See the post. There are at least 2 vendors and you can Google some of the various PN. I DO hope you labeled the wires and took a picture or made a diagram. I know how this switch works and the various wires, but the diagram baffles me and I have studied it a few times, http://www.nwrvsupply.com/product/DG44A28VP.html there are,5 contacts. their are the following leads or wires Ground to the switch. The way it works, the momentary contact switch sends a ground signal back to the pump controller. So that is 2. there is a “hot” or the ON circuit that is in parallel with the pump. So when the pump is ON, that lead powers the indicator light. Up to 3. The light needs a ground, so the incoming ground is tied or connected to the OTHER side of the pilot or ON light. therefore, you only need 4 wires. I don’t know the other terminal. Good luck Link to comment Share on other sites More sharing options...
