Timmy C. Posted September 7, 2022 Share Posted September 7, 2022 I have 2006 Monaco Windsor, tried to lock the door and bay doors with the keypad but they will not lock. Used the key fob and it will lock and unlock both entry door and bay doors just fine. The keypad will also unlock both sets of doors as it should. The keypad beeps when the keys are pushed and sounds like it always has. I'm at a loss on this one, any ideas? Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 7, 2022 Share Posted September 7, 2022 Replace the keypad Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 7, 2022 Share Posted September 7, 2022 1 hour ago, Timmy C. said: I have 2006 Monaco Windsor, tried to lock the door and bay doors with the keypad but they will not lock. Used the key fob and it will lock and unlock both entry door and bay doors just fine. The keypad will also unlock both sets of doors as it should. The keypad beeps when the keys are pushed and sounds like it always has. I'm at a loss on this one, any ideas? Chuck is our Windsor guy. But if you have the Trimark and not the Essex, I would call Trimark and talk to them. There is a diagnostic and such that might clear the issue. Memory says that Trimark said to go into the “setup” or configure mode….then back out. No changes. They also have a good manual. Just verify you have the Trimark system first, let us know what they say and what you find out. Thanks. Link to comment Share on other sites More sharing options...
Timmy C. Posted September 7, 2022 Author Share Posted September 7, 2022 Thanks guys I'll give Trimark a call. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 8, 2022 Share Posted September 8, 2022 The Essex KE 1700 series keypad requires two actions to operate the keypad when the button is pushed. The first action is the pressure on the button to make contact and the second action is the heat from the finger pushing the button. After years of use the button does not release when pushed. The sun shinning on the keypad provides the heat. Then the two conditions are met. That is why the keypad will operate opening and closures at random times. That is why I recommend replacing the keypad. Link to comment Share on other sites More sharing options...
Russ R Posted September 8, 2022 Share Posted September 8, 2022 You should be able to lock the door and bay doors by just entering 555 on the key pad. Link to comment Share on other sites More sharing options...
Tom Westerfield Posted September 8, 2022 Share Posted September 8, 2022 I push #1button to lock the rig and storage doors. If I don't hear a click indicating lock Clean the contacts on the inside hinge side of the door jamb with an eraser, oooo steel woll or very fine sandpaper. Happens about once a year. Tom Westerfield 2006 windsor Link to comment Share on other sites More sharing options...
Grampy OG Posted September 11, 2022 Share Posted September 11, 2022 Occasionally my TriMark goes out of sync. This happens a couple of times a year. The fix for me is to wait until the system settles and then enter the full 4 digit UNLOCK code. I usually don't get a response but then when I hit the old 555 I get the satisfying sound of locks engaging all around the coach. Usually to unlock all I hit the first 3 numbers and then the number "9". I don't know what causes the sync issue. Good luck Ken Link to comment Share on other sites More sharing options...
