[email protected] Posted October 19, 2022 Posted October 19, 2022 While driving home yesterday, turn signal lever broke when activated to change lanes. Handle appears fine, but small plastic part broke off. Turn signal is now stuck in right turn mode. Without pulling the fuse, any suggestions on how to turn off? Who might have the parts to repair and is it easy fix? Thanks, Jim Boland Monaco Camelot 42KFQ
jacwjames Posted October 19, 2022 Posted October 19, 2022 You might try a screw driver to see if you can get it to go back to center location. My steering column is a Douglas Autotech. The turn signal switch is a TS012 based on the parts diagram I have for my coach, here are 3 listed on ebay with a WIDE range in price. https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=turn+signal+kit+TS012&_sacat=0 If the plastic is broke not sure if JB weld would work or not, worth a try.
Happycarz Posted October 19, 2022 Posted October 19, 2022 This is the switch assembly from just one source. You can google the part number it to find other sources, too. https://mpparts.com/part/douglas-autotech-1900008-tilt-turn-signal-switch-kit-1900008 Once the upper and lower plastic shrouds are removed from the upper column, the switch can be unbolted and wires disconnected.
Tom Wallis Posted October 19, 2022 Posted October 19, 2022 I'm not sure what broke. If it was the lever then you should be able to turn the wheels to the right and back and cancel the signal. If it was the internal latching mechanism then you should be able to turn it off with the lever.
