Larry Maida Posted November 1, 2022 Share Posted November 1, 2022 Ok so this is probably going to give you talented folks a chuckle but here goes. I cannot figure out how to get my storage bay lights to go on. I remember replacing all of the bulbs and they all worked well: so today I tried to turn them on. There is a switch by pass seat with an indicaror light. There is another in the wet bay. Nothing. I do kinda remember there was something else that needed to be done. I tried having the marker lights on. I tried turning the headlight switch to light the map lights. Nothing. Can someone give me a clue? Link to comment Share on other sites More sharing options...
tmw188 Posted November 1, 2022 Share Posted November 1, 2022 Are they all doing this? You didn’t by chance turn any of the battery disconnect switches off and forgot doing so? Link to comment Share on other sites More sharing options...
Ray Davis Posted November 1, 2022 Share Posted November 1, 2022 I have a switch in the pass overhead cabinet. Link to comment Share on other sites More sharing options...
TommyL Posted November 2, 2022 Share Posted November 2, 2022 I had a bad relay in my electrical bay ,kept blowing fuse. Replace relay,all good.2008 camelot. It would test good then bad , also just because a fuse shows continuity doesn’t always mean it’s good! Link to comment Share on other sites More sharing options...
CLIFF918 Posted November 2, 2022 Share Posted November 2, 2022 Hi Larry, I have an 02 Diplomat as well and all my bay lights are controled by the switch next to the passenger seat. Check your wet bay also, when you open the right hand wet bay door your storage bay light should lite as well as the Left hand wet bay compartment light. There is a switch in the upper right of the wet bay door that controls the lights when you open the bay door. check that switch mine had rusted and was not working, was able to clean it up and lube it but have heard that some have had to change out the switch. It is a plunger type switch that we had on our older cars that turned on the dome light. If those are working then I would say the power is good if not I would be looking for a bad fuse. 1 Link to comment Share on other sites More sharing options...
Larry Maida Posted November 4, 2022 Author Share Posted November 4, 2022 Thank you all for your responses. Both my switches are good so I guess its probably a fuse. Well thats where I will start. I thought maybe it needed the lights to be on or something. Thanks again! Link to comment Share on other sites More sharing options...
jacwjames Posted November 4, 2022 Share Posted November 4, 2022 I've got a 15 amp fuse in my front drivers side electrical bay labeled "Storage Lights". Link to comment Share on other sites More sharing options...
Larry Maida Posted November 4, 2022 Author Share Posted November 4, 2022 Thanks Jim! Yup there it was. How does that saying go? Start with the simplest solution dum dum. 😂 Link to comment Share on other sites More sharing options...
jacwjames Posted November 4, 2022 Share Posted November 4, 2022 I got tired of trying to find info on fuse descriptions so I took a picture of each of my fuse panels and can quickly look at the pictures and fine the info. Link to comment Share on other sites More sharing options...
