birdshill123 Posted November 2, 2022 Share Posted November 2, 2022 Lately I have been getting the symptoms of a faulty ignition switch. Sometimes you turn the key and all is good. Sometimes nothing happens. I remembered reading about this problem since we first aquired our Dynasty. I am positive it is the switch. I watched the videos on removing the bezel and then the tumbler assembly. As an aside one of those videos was from a "good old guy". In order to turn the bezel he put a big screwdriver on the indent and used a hammer to beat some sense into that bezel. WOW! I see a whole bunch of different part # but it is supposed to be from a 68 to 72 Chev PU. Is that correct? Thanks Link to comment Share on other sites More sharing options...
StephenW Posted November 2, 2022 Share Posted November 2, 2022 I just replaced the ignition switch on my '01 Dynasty and got a '72 Chevy pickup ignition switch from tne local NAPA auto parts, Once the bezel moved a bit , it was easy to remove the rest of the way by hand. I was having intermittent problems with the accessory solenoid turning on and off. Since replacement the accessory solenoid turns on each time. 1 Link to comment Share on other sites More sharing options...
Bob Danny Posted November 3, 2022 Share Posted November 3, 2022 We have been having the same problem I have a 2011 diplomat and used this switch. All though it did not fix the problem the switch still worked. Link to comment Share on other sites More sharing options...
veraken Posted November 3, 2022 Share Posted November 3, 2022 Agree, this is what you need https://www.napaonline.com/en/p/ECHKS6603 https://www.autozone.com/batteries-starting-and-charging/ignition-switch/p/duralast-ignition-switch-ls411/122366_0_0 Link to comment Share on other sites More sharing options...
