ok-rver Posted December 14, 2022 Share Posted December 14, 2022 I have access to the Cummins Quickserve site and have reviewed the diagram 3666267-03 they have available. I did not see any wiring/connections to the CAPS system. Wondering if any one has a diagram that would show any of the 4 pin connectors used on the pump. 2004 8.3 ISC Link to comment Share on other sites More sharing options...
JDCrow Posted December 14, 2022 Share Posted December 14, 2022 Injection Control Valve on the side plug? Link to comment Share on other sites More sharing options...
ok-rver Posted December 14, 2022 Author Share Posted December 14, 2022 that's probably one on the connectors. located under the pump. not the accumulator connector on top Link to comment Share on other sites More sharing options...
JDCrow Posted December 14, 2022 Share Posted December 14, 2022 (edited) Ok I didn’t see where you mentioned the plug coming from accumulator, sorry, ICV is also 4 pin. It’s under the accumulator, on top of rotary manifold The plugs coming off the pressure sensors on top of accumulator. I’ll look for wiring diagram Edited December 14, 2022 by JDCrow Link to comment Share on other sites More sharing options...
ok-rver Posted December 14, 2022 Author Share Posted December 14, 2022 looked up ICV and a picture shows that it is the connector I am looking for. the end going to the ECM away from the ICV has a 4 pin square connector. two of those wires appear to go to the ICV. The other two wires go about 3" to a two pin connector. This connector on my motor home is not connected to anything. I am looking for a wiring diagram to determine the function of this pair of wires and if they should be connected. Link to comment Share on other sites More sharing options...
