JustaRamble Posted March 21, 2023 Share Posted March 21, 2023 Has anyone replaced the rubber seal around their storage bays? Several of mine are pretty bad shape. It appears that there is metal wire in the slot to help it grip the body lip. Anyone have a source and part #? Link to comment Share on other sites More sharing options...
Steve P Posted March 21, 2023 Share Posted March 21, 2023 First stop: steelerubber.com 1 1 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 21, 2023 Share Posted March 21, 2023 Over the years, by dragging objects over the gasket, the rubber would tear and expose the metal in it. What I did was rotate the gasket to put the beat-up section on top and the, like new, on the bottom. Gary 05 AMB DST 2 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted March 21, 2023 Share Posted March 21, 2023 This is what I bought. https://www.amazon.com/gp/product/B00NL40XQI/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&th=1 Link to comment Share on other sites More sharing options...
Solution LakeBob Posted March 23, 2023 Solution Share Posted March 23, 2023 Steele Rubber Products - Thin Side Lip Push-On Seal | RV Seal | Steele Rubber Products This is what I used. Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted March 23, 2023 Share Posted March 23, 2023 36 minutes ago, LakeBob said: Steele Rubber Products - Thin Side Lip Push-On Seal | RV Seal | Steele Rubber Products This is what I used. LakeBob, Thanks for the link. I like the seal but it is not like the seals that came on our earlier Monacos with the lift-up bay doors. My 03 Windsor came with a seal like my picture above. I don't know if your seal could work on my Windsor or not, but I don't think so. Link to comment Share on other sites More sharing options...
LakeBob Posted March 23, 2023 Share Posted March 23, 2023 Ah, yes different seal. I’ve had good luck with some suppliers on Amazon as well. Link to comment Share on other sites More sharing options...
JustaRamble Posted April 4, 2023 Author Share Posted April 4, 2023 On 3/22/2023 at 9:06 PM, LakeBob said: Steele Rubber Products - Thin Side Lip Push-On Seal | RV Seal | Steele Rubber Products This is what I used. This looks like the original seals on mine. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 4, 2023 Share Posted April 4, 2023 $8.29/ft? On mine I rotated the gasket, top to bottom. Good for another 12 yrs. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted April 4, 2023 Share Posted April 4, 2023 In all likely hood, a stick-on seal of some sort from Lowes or Home Depot could be made to work. Much cheaper too. Link to comment Share on other sites More sharing options...
RoadTripper2084 Posted April 5, 2023 Share Posted April 5, 2023 I recently replaced a bunch of mine, found the same type at a local hardware chain "Princess Auto" aka "China" auto. Kind of like an off-brand Harbour Freight, but in Canada. Anyway, wasn't expensive at all. Link to comment Share on other sites More sharing options...
