Joel J Posted April 14, 2023 Share Posted April 14, 2023 Both rear slides do not go in. When pushing the button, the circuit at the fuse board lites, the fues are good. Where is the motor located? We are trying to leave Happy Trails in AZ Link to comment Share on other sites More sharing options...
Joel J Posted April 14, 2023 Author Share Posted April 14, 2023 I just checked the front slide and it does not work either. The touch pad buttons lite up, the and the fuse board make a tic sound and shows that the circuit is good to there. Going to check the connections at the hyd pump now. Link to comment Share on other sites More sharing options...
Frank Bergamo Posted April 14, 2023 Share Posted April 14, 2023 (edited) There is a relay solenoid on the pump motor. It is usually located in front of the entry door steps. The solenoid is mounted with a band clamp around the motor. Get your volt meter and see if you have power to the solenoid. Also check the trigger terminal for power while someone presses the switch inside. I found a new solenoid at a trailer parts house. They use them on dump trailers. Pretty common part. Hope this helps. Also, you can jumper the two large terminals on the solenoid to close the slides. Have someone push the desired slide retract button while jumping the big terminals on the solenoid. Do this till all slides are closed. It will get you by until you can replace the solenoid. Edited April 14, 2023 by Frank Bergamo Link to comment Share on other sites More sharing options...
timaz996 Posted April 14, 2023 Share Posted April 14, 2023 Check you storage compartment doors below the slides to make sure the safety switches are working. Link to comment Share on other sites More sharing options...
Guest Jester1 Posted April 14, 2023 Share Posted April 14, 2023 Ditto on storage doors and check that your inverter is on. For some reason mine has to be on, shore power or not. Link to comment Share on other sites More sharing options...
Joel J Posted April 15, 2023 Author Share Posted April 15, 2023 Good news, When you have 9 year old chassis batteries, its time to replace them!!! That was the problem. Link to comment Share on other sites More sharing options...
