63Hotrod Posted April 23, 2023 Share Posted April 23, 2023 For general PM I want to clean up the grounds. I am trying to trace where the House and start battery's ground. Located the house in almost impossible to get location. Top of frame rail behind the rear inverter compartment. Not quite sure how to squeeze my old bones in there Have not been able to trace the start battery cable. It goes into a big cable bundle headed aft If I can't get to them I may relocate to a more serviceable place. Anyone done that Link to comment Share on other sites More sharing options...
MyronTruex Posted April 23, 2023 Share Posted April 23, 2023 No, but using a headlamp after dark helps find some of the ground locations. Moving the grounds would be fine and give you the opportunity to really get some clean and shiny place to connect to. Link to comment Share on other sites More sharing options...
63Hotrod Posted April 25, 2023 Author Share Posted April 25, 2023 Just an update House ground is a stud welded to the top of the frame rail behind the aft bay on the passenger side. Access is thru the bedroom hatch Still chasing the start battries Link to comment Share on other sites More sharing options...
