RoadTripper2084 Posted May 1, 2023 Share Posted May 1, 2023 At the risk of looking foolish, I can't seem to locate the serial # tag on my Cummins C8.3 engine. I figured lots of folks here probably know exactly where I should look. I have the C8.3 engine, which I believe is also known as the "6CTA" series. This is what Cummins says about it: I can't really access the spot on the top of the left-side of the block, I took a few pictures but couldn't see anything. They mention that "the long narrow metal tag is attached to the front cover/gear housing...". Any ideas where I would look for that? Link to comment Share on other sites More sharing options...
JDCrow Posted May 1, 2023 Share Posted May 1, 2023 Your picture looks like for a 5.9 Cummins I believe my data plate on our 8.3 was on the front cover top near where the oil hose attached. To looking at engine from rear of coach, it’s top right Link to comment Share on other sites More sharing options...
Solution tmw188 Posted May 1, 2023 Solution Share Posted May 1, 2023 (edited) Yes up behind this area on the top right if I remember correctly. Looks like this Edited May 1, 2023 by tmw188 Link to comment Share on other sites More sharing options...
RoadTripper2084 Posted May 1, 2023 Author Share Posted May 1, 2023 Thanks guys, found it immediately based on your advice. Link to comment Share on other sites More sharing options...
