Davinci Posted June 30, 2023 Share Posted June 30, 2023 Have a 1999 Monaco diplomat. The top latch won't release, the bottom works fine. I've tried the trick of pushing in to release tension before pulling back. I was able to get the inside panel over the handle off to access the mechanism, I've tried with pliers and channel locks to pull down on the rod going up to the top but it doesn't move anymore than what the handle makes it move. I'm not sure what else to do and I don't want to break anything or make it worse. Just as fyi about 2 years ago I had to adjust the linkage since the top wouldn't release unless I pushed in before trying to open it but this time same trick isn't working. I've watched the youtube from AZ experts and still unable to get the top to release. Link to comment Share on other sites More sharing options...
gdroberson Posted July 1, 2023 Share Posted July 1, 2023 can you unhook the linkage from the latch so you can get more movement out of it Link to comment Share on other sites More sharing options...
Steve Merritt Posted July 1, 2023 Share Posted July 1, 2023 I had that happen to me a few times in our 2000 Endeavor that was on the Freightliner chassis same length and we would have to use the front leveling jacks and just barely bump the switches to the jacks and keep trying the door and it would always eventually open. I loosened the top post and lubricated it and the latch with chain saw chain lubricant in a spray can and it stopped hanging up after that I just sprayed it about every 3 months Link to comment Share on other sites More sharing options...
Davinci Posted July 3, 2023 Author Share Posted July 3, 2023 Finally got the door open after I stuck an inspection camera up there. I will readjust the linkage next so it doesn't happen again. Link to comment Share on other sites More sharing options...
Agpopp Posted July 3, 2023 Share Posted July 3, 2023 We all figured you were still stuck in there! How'd you pop it? Link to comment Share on other sites More sharing options...
