wamcneil Posted July 3, 2023 Share Posted July 3, 2023 (edited) Have y'all seen this? LockNFlate Locking Air Chuck - Six Steel Jaws Lock onto Any tire Valve - Won't Leak or pop Off - Rated to 150 PSI It's an air chuck from the LockNLube folks that have a similar locking grease coupler. I'd tried locking air chucks several times in the past and have always been disappointed and went back to a regular press-on chuck. This thing is pretty expensive for a tire chuck, but I must say that I'm loving this locknflate ! Instead of two thin blades of sheetmetal to grab the threads and hold the valve stem inside the chuck, it's got 6 threaded fingers, kind of like an internally threaded collet. These fingers each engage several threads on the valve stem and pull it securely up against the seal. For regular car tires I wouldn't care that much. But It's a real pain to hold a chuck on those bus tires... I splurged and put the locknflate on a new Milton digital inflator. Cheers, Walter Edited July 3, 2023 by wamcneil 2 Link to comment Share on other sites More sharing options...
Donflem Posted July 4, 2023 Share Posted July 4, 2023 I have the grease gun one. Did you get it on Amazon? Link to comment Share on other sites More sharing options...
Paul J A Posted July 4, 2023 Share Posted July 4, 2023 https://locknlube.com/products/locknflate-dual-wheel-adapter?variant=39750908903508¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&nbt=nb%3Aadwords%3Ag%3A19697562718%3A149987731390%3A648340416621&nb_adtype=pla&nb_kwd=&nb_ti=pla-293946777986&nb_mi=420168296&nb_pc=online&nb_pi=shopify_US_6742261792852_39750908903508&nb_ppi=293946777986&nb_placement=&nb_li_ms=&nb_lp_ms=&nb_fii=&nb_ap=&nb_mt=&gclid=Cj0KCQjwho-lBhC_ARIsAMpgMocxq3Wr0EfRxYSXQQ4tzRySBlVmr2xGlY8rCNLBH-uWYk21ICy3w-YaAhvqEALw_wcB 17 hours ago, wamcneil said: Have y'all seen this? LockNFlate Locking Air Chuck - Six Steel Jaws Lock onto Any tire Valve - Won't Leak or pop Off - Rated to 150 PSI It's an air chuck from the LockNLube folks that have a similar locking grease coupler. I'd tried locking air chucks several times in the past and have always been disappointed and went back to a regular press-on chuck. This thing is pretty expensive for a tire chuck, but I must say that I'm loving this locknflate ! Instead of two thin blades of sheetmetal to grab the threads and hold the valve stem inside the chuck, it's got 6 threaded fingers, kind of like an internally threaded collet. These fingers each engage several threads on the valve stem and pull it securely up against the seal. For regular car tires I wouldn't care that much. But It's a real pain to hold a chuck on those bus tires... I splurged and put the locknflate on a new Milton digital inflator. Cheers, Walter Thanks. Great!! https://locknlube.com/products/locknflate-dual-wheel-adapter?variant=39750908903508¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&nbt=nb%3Aadwords%3Ag%3A19697562718%3A149987731390%3A648340416621&nb_adtype=pla&nb_kwd=&nb_ti=pla-293946777986&nb_mi=420168296&nb_pc=online&nb_pi=shopify_US_6742261792852_39750908903508&nb_ppi=293946777986&nb_placement=&nb_li_ms=&nb_lp_ms=&nb_fii=&nb_ap=&nb_mt=&gclid=Cj0KCQjwho-lBhC_ARIsAMpgMocxq3Wr0EfRxYSXQQ4tzRySBlVmr2xGlY8rCNLBH-uWYk21ICy3w-YaAhvqEALw_wcB Link to comment Share on other sites More sharing options...
wamcneil Posted July 4, 2023 Author Share Posted July 4, 2023 11 hours ago, Donflem said: I have the grease gun one. Did you get it on Amazon? Yes. They’re on Amazon. Two versions; the open type to use with an inflator and closed to go straight on the end of the air hose. Link to comment Share on other sites More sharing options...
Tony G. Posted July 4, 2023 Share Posted July 4, 2023 I use this one for better access to the rear duall tires Link to comment Share on other sites More sharing options...
Gene Y Posted July 5, 2023 Share Posted July 5, 2023 On 7/3/2023 at 6:07 PM, wamcneil said: Have y'all seen this? LockNFlate Locking Air Chuck - Six Steel Jaws Lock onto Any tire Valve - Won't Leak or pop Off - Rated to 150 PSI It's an air chuck from the LockNLube folks that have a similar locking grease coupler. I'd tried locking air chucks several times in the past and have always been disappointed and went back to a regular press-on chuck. This thing is pretty expensive for a tire chuck, but I must say that I'm loving this locknflate ! Instead of two thin blades of sheetmetal to grab the threads and hold the valve stem inside the chuck, it's got 6 threaded fingers, kind of like an internally threaded collet. These fingers each engage several threads on the valve stem and pull it securely up against the seal. For regular car tires I wouldn't care that much. But It's a real pain to hold a chuck on those bus tires... I splurged and put the locknflate on a new Milton digital inflator. Cheers, Walter That looks awesome, thanks for sharing! It is a real PITA to use a press on chuck. 1 Link to comment Share on other sites More sharing options...
