JeffM31 Posted July 9, 2023 Share Posted July 9, 2023 (edited) Good morning, I have always been a fan of Leisure Led so I thought I would share the lights. The main old thin lights are what were changed here. They almost cover all of the thin light imprint. Super happy with these. They have Off, 25%, 50%, 75%, and 100%. I ordered them in natural light. These were basically plug and play. As long as they are centered up they will screw into the aluminum. The other link is the screws I used to mount them. Night and day difference. https://www.amazon.com/dp/B0BF5Z2L6N?ref=ppx_yo2ov_dt_b_product_details&th=1 https://www.amazon.com/dp/B09MDZY3Q3?psc=1&ref=ppx_yo2ov_dt_b_product_details The puck lights I ordered are these, huge difference also. Same natural light also. These are plug and play also, they fit directly in the hole. https://www.amazon.com/dp/B07WPY398C?psc=1&ref=ppx_yo2ov_dt_b_product_details All of the storage light bulbs I changed to these. They seem to be plenty bright. Same bulb for the porch light too. https://www.amazon.com/dp/B08LCZ2R7T?ref=ppx_yo2ov_dt_b_product_details&th=1 The bathroom fixtures, wall sconces, map lights and outside step light I used these bulbs. Super bright also. https://www.amazon.com/dp/B09Y5JQFP1?psc=1&ref=ppx_yo2ov_dt_b_product_details I removed the front and rear compartment pull lights and added these instead. Yes they are bright https://www.amazon.com/dp/B072BJHTGK?psc=1&ref=ppx_yo2ov_dt_b_product_details In the kitchen I ordered these. The ballast have to be removed. I haven't received them yet but the reviews are great. https://m4products.com/t8-36tube-nw-natural-white-36-f30t8-12-volt-t8-led-tube-light-4500k/ I changed out the camera monitor because I had a line in it. The new monitor was not compatible with the Aladdin so I ordered this small monitor to see Aladdin https://www.amazon.com/dp/B0746CM3G7?psc=1&ref=ppx_yo2ov_dt_b_product_details This is the new monitor I used https://www.amazon.com/dp/B083G5GGCJ?psc=1&ref=ppx_yo2ov_dt_b_product_details Along with changing out the cooling unit in my no cold this is the bright LED bulb I used for that https://www.amazon.com/dp/B07DGX84MR?psc=1&ref=ppx_yo2ov_dt_b_product_details Off topic of LED's I decided to change the U-joint. Not that bad of job with the right tools. https://www.amazon.com/dp/B0084FF710?psc=1&ref=ppx_yo2ov_dt_b_product_details My transmission wasn't reading any temp and found out its because Monaco used a 400 degree sensor. I ordered a 300 degree and all is well. The gauge will actually show about in the middle now. If you're fast you can change it without losing much fluid. https://www.amazon.com/dp/B07KJT6B5K?psc=1&ref=ppx_yo2ov_dt_b_product_details Head light switch was 100 bucks from RV places. Its a basic Chevy switch. This is it for 26 and some change https://www.amazon.com/dp/B000C9SAJC?psc=1&ref=ppx_yo2ov_dt_b_product_details Went ahead and straight piped the exhaust too. Couple hundred and done Hopefully this can be helpful to a few Jeff Edited July 9, 2023 by JeffM31 Forgot a link 1 Link to comment Share on other sites More sharing options...
Bootlegger 659 Posted July 9, 2023 Share Posted July 9, 2023 Thanks Jeff, for supplying the links for these simple upgrades! Makes completing these task's so much easier. Link to comment Share on other sites More sharing options...
JeffM31 Posted July 9, 2023 Author Share Posted July 9, 2023 3 minutes ago, Bootlegger 659 said: Thanks Jeff, for supplying the links for these simple upgrades! Makes completing these task's so much easier. You're very welcome. Any questions feel free to reach out Link to comment Share on other sites More sharing options...
Bill R Posted July 9, 2023 Share Posted July 9, 2023 5 hours ago, JeffM31 said: Went ahead and straight piped the exhaust too. Couple hundred and done Jeff - so did you eliminate the muffler? If so, any noticeable difference in performance or noise? Link to comment Share on other sites More sharing options...
JeffM31 Posted July 9, 2023 Author Share Posted July 9, 2023 (edited) 56 minutes ago, Bill R said: Jeff - so did you eliminate the muffler? If so, any noticeable difference in performance or noise? Yes, muffler is gone. Haven't driven it yet to see any difference. The noise is there when on the throttle but honestly I don't feel its obnoxiously loud at all. Edited July 9, 2023 by JeffM31 1 1 Link to comment Share on other sites More sharing options...
RoadTripper2084 Posted July 10, 2023 Share Posted July 10, 2023 58 minutes ago, JeffM31 said: Yes, muffler is gone. Haven't driven it yet to see any difference. The noise is there when on the throttle but honestly I don't feel its obnoxiously loud at all. Try standing on the sidewalk next to the exhaust and having someone rev the motor up a bit. You might be surprised how obnoxious it is. 1 Link to comment Share on other sites More sharing options...
JeffM31 Posted July 10, 2023 Author Share Posted July 10, 2023 I did. I like it. It may just be preference. I may change my mind towing a grade but for now I love it. 1 Link to comment Share on other sites More sharing options...
JeffM31 Posted July 12, 2023 Author Share Posted July 12, 2023 Just drove it to get tires, it sounds great. Love the increased turbo whistle too Link to comment Share on other sites More sharing options...
Bill R Posted July 13, 2023 Share Posted July 13, 2023 @JeffM31 Do you feel like your coach has more power with the straight pipe? Link to comment Share on other sites More sharing options...
JeffM31 Posted July 13, 2023 Author Share Posted July 13, 2023 I didn’t notice much honestly maybe a tad. It was just city streets. In the long run it should give me a tiny increase in fuel and definitely help to lower the egt’s. Link to comment Share on other sites More sharing options...
