goetzctaz Posted August 3, 2023 Share Posted August 3, 2023 I have a 9702 Kingdome Satellite on my RV; have had it for 20 years; it was working 3 months ago and I have never had a problem with this satellite until now. The RV is covered in a RV garage. When I do a search outside of the RV garage, it seems to home in/connect on the satellite; both lights are green on the search remote which is an indication that it found the satellite. On the TV, a message is produced stating that the satellite is acquiring information with a red dot and stating that 9% is complete, but it never moves beyond the 9% mark. The receiver is a Directv DVR R10. What can be causing this problem; why won’t it finish acquiring the rest of the 91% data? Is it the R10? King Connect won't answer my question. Link to comment Share on other sites More sharing options...
cbr046 Posted August 3, 2023 Share Posted August 3, 2023 Similar situation a number of years ago but with Dish Network. Turned out Dish had changed their encoding from the satellite and the only solution was to purchase a new $400 board from King Controls to go inside the dome. I declined and made a quad pod with PVC and a regular roof dish. Works great. - bob Link to comment Share on other sites More sharing options...
dandick66 Posted August 4, 2023 Share Posted August 4, 2023 You might want to call Directv support and talk to them. Be prepared for a run around asking you to check everything under the sun. You need to get the issue escalated to the department that has a higher level of support. Tell them you’re trying to find out if they’ve made programming changes in the last 3 months that would affect your unit. Also, you might want to try googling the problem you’re experiencing. There are a few forums that deal with Directv and Dish problems. I think 1 of the is Satguys. Link to comment Share on other sites More sharing options...
goetzctaz Posted September 5, 2023 Author Share Posted September 5, 2023 Will do, thank You. Link to comment Share on other sites More sharing options...
goetzctaz Posted October 14, 2023 Author Share Posted October 14, 2023 I called Directv; had them remove/add my receiver from their system; voila it worked and I was watching Directv. I had read this somewhere and thought nothing to loose and much to gain. Link to comment Share on other sites More sharing options...
dennis.mcdonaugh Posted October 15, 2023 Share Posted October 15, 2023 I don’t know if your dish is SD or not, but the last SD satellite was scheduled to go dark soon, they didn’t have the exact date, but the last I heard, it was about now. i here’s some discussion on Direct TV forums. https://forums.directv.com/conversations/community-lounge/why-is-directv-taking-away-my-channels/62490de1a7e2d409585cec94# Link to comment Share on other sites More sharing options...
goetzctaz Posted October 16, 2023 Author Share Posted October 16, 2023 Dennis, thank you for responding. When I called DirecTv to do a delete/add on my receiver, I asked them about this rumor/fact that has been going on for several years. They indicated that there were no future plans to take away SD connection. Yes. my satellite/receiver is SD. Link to comment Share on other sites More sharing options...
