Ken Thompson Posted October 7 Share Posted October 7 (edited) 2001 Monaco Dynasty hydraulic slide out needs the top to go out further to seal. The bottom goes all the way out and seals, but the top doesn’t quite go out and seal on the front of my slide. I see the adjusting nuts in the tube on both sides, but I think there must be another adjuster somewhere else. Edited October 7 by Ken Thompson Link to comment Share on other sites More sharing options...
Bill Hines Posted October 7 Share Posted October 7 Ken, I know on mine their are shims that go either top or bottom of brkt that attaches slide cylinders to slide. Very basic adjustment. maybe some others have a different idea. bill Link to comment Share on other sites More sharing options...
Ray Davis Posted October 7 Share Posted October 7 Have you checked for something on top of the slide? ( inside ) 1 Link to comment Share on other sites More sharing options...
timaz996 Posted October 7 Share Posted October 7 (edited) There is a large nut that locks an allen head screw on the bottom of each arm under the slideout. Loosen the nut and adjust the allen head screw. I can't remember which direction but those screws adjust the top in/out. Edited October 7 by timaz996 Link to comment Share on other sites More sharing options...
96 EVO Posted October 7 Share Posted October 7 3 hours ago, Ken Thompson said: I see the adjusting nuts in the tube on both sides, but I think there must be another adjuster somewhere else. Probably not. You likely need to adjust the inside nut/ locknut on that side, so that it doesn't/ can't push the bottom as far as it is. May only need a couple of turns. Link to comment Share on other sites More sharing options...
