Donflem Posted November 7 Share Posted November 7 So I found this the other day. The refrigerator has always leaked on that spot on travel days so I always put a towel down. I take that drawer out a few times a year and it’s always dry so I thought the towel was doing its job. I’m wondering what your suggestions would be? On a side note what do you guys recommend for polishing the wood throughout the place. Thanks in advance Don Link to comment Share on other sites More sharing options...
jacwjames Posted November 7 Share Posted November 7 I assume the loose tile is under the refrigerator. Can you tell if any other tile are loose? If you softly tap on them with a mallet or piece of wood do they all sound as if they are still fastened down. Loose will give you a hollow sound. If no other tiles are loose I don't think I'd do anything, you'd probably end up with a bigger problem. If other tiles are loose it might mean the wood is starting to rot and you've got a bigger problem. Link to comment Share on other sites More sharing options...
Solution Donflem Posted November 8 Author Solution Share Posted November 8 I’ll try that tomorrow thanks. Link to comment Share on other sites More sharing options...
