laurice@email.com Posted November 8 Share Posted November 8 Quick question. Can I exercise my generator while on shore power? I just replaced the automatic transfer switch and not sure if the exercising was the cause or nearly a coincidence. Thanks in advance Laurice Link to comment Share on other sites More sharing options...
1nolaguy Posted November 8 Share Posted November 8 Assuming you have an on-board generator, consider exercising it when you move. I generally do this once month when moving from one CG to another. I try to run the generator while on the freeway so it gets good air exchange and I run the A/C or Heat Pump as a load about the last 15-20 minutes before I get to my stop to cool down or warm up the living quarters as needed. Link to comment Share on other sites More sharing options...
cbr046 Posted November 8 Share Posted November 8 If there was load on the transfer switch while it switched that could be an issue (switching under load), but I doubt the exercising was the cause. - bob Link to comment Share on other sites More sharing options...
96 EVO Posted November 8 Share Posted November 8 (edited) 30 minutes ago, laurice@email.com said: Quick question. Can I exercise my generator while on shore power? I just replaced the automatic transfer switch and not sure if the exercising was the cause or nearly a coincidence. Thanks in advance Laurice Remove any large loads before starting the generator and it will usually be fine. I burned up the gen time delay board in my transfer switch doing what you want to do, when my gen didn't start due to a problem under the hood! I now shut off the shore power breaker before starting the generator! Edited November 8 by 96 EVO Link to comment Share on other sites More sharing options...
laurice@email.com Posted November 8 Author Share Posted November 8 Thanks all. Great information and confirmed was I thinking. we are full timers in southern BC so it can get a little col in the winter but based on your advise, we’ll venture out and throw the main break going forward. m Many thanks for the info. Much appreciated Link to comment Share on other sites More sharing options...
96 EVO Posted November 8 Share Posted November 8 I'm on the west coast of B.C. I've visited Fort Steele. Cool little place! Link to comment Share on other sites More sharing options...
Solution CAT Stephen Posted November 8 Solution Share Posted November 8 Laurice, Although transfer switches are designed to transfer under load, arcing does occur under all loads and the arcing is heavier and more severe as the load increases. Arcing causes corrosion of the electrical contactors within the transfer switch which results in eventual transfer switch failure. So, should you use your transfer switch under load? The answer is that is exactly what it is designed for. But, since most all transfer switches are inherently slow in their load transfer (defined as the momentary absence of power during the transfer from shore to generator or generator to shore), your air conditioners, microwaves, and clothes washers will cycle off during the transfer which is not helpful. Thus, its better to power off the heavy loads before the transfer as they will just cause more arcing with no other benefit which reduces the service life of your transfer switch. Also, keep in mind that all RV transfer switches are set from the factory as being generator preferred. What this means is that the transfer switch will activate within a preset time (30 seconds to 2 minutes depending on your transfer switch) switching the load from shore to generator even if your RV is attached to shore power. Your results may vary as some transfer switches have DIP switches to adjust the generator preference to shore power preference. Link to comment Share on other sites More sharing options...
laurice@email.com Posted November 8 Author Share Posted November 8 Great response. Thank you so much. Link to comment Share on other sites More sharing options...
Rocketman3 Posted November 8 Share Posted November 8 One other issue of having the shore on and then starting the generator is when the transfer happens the sign waves of the power will not be in sync and probably not even close. (The same thing when running the generator then shutting it down and the transfer switch immediately switches back to grid). While this will be fine for some loads - it can cause problems for other items - especially stuff with computer chips in them. Link to comment Share on other sites More sharing options...
1nolaguy Posted November 8 Share Posted November 8 As a rule of thumb, it is just better when you are going to exercise your generator, and you are plugged into shore power, turn off the breakers at the pedestal before you start the generator and cut off the generator before you turn on the breakers again. That keeps the systems separate and buts less strain on the transfer switch. 2 Link to comment Share on other sites More sharing options...
laurice@email.com Posted November 22 Author Share Posted November 22 Thanks all. Much appreciated Link to comment Share on other sites More sharing options...
