Bob Wightman Posted December 11, 2023 Share Posted December 11, 2023 Hello Group! I'm a new owner of a 2006 Holiday Rambler Scepter and am beginning the process of getting her fixed up. One of the things thats needs attention is the drivers side living room slide out cover. It works but its sagging onto the slide-out roof, I'm assuming it needs one or both of the springs. I know its a Carefree awning, I just don't know what model it is. There are two options "Ascent" (which is what I think it is) and due to the length (13') I assume its the XL (and since it still retracts I assume one of the springs is still good), or it could be the Slideout Kover III (but that one only shows 1 spring). I'm assuming some of you have already had to repair your slideout covers, and was hoping you could confirm which model to order parts from (don't want to get it wrong as shipping from CareFree is $180 bucks). I also would like to add LED lighting to the outside of the coach to be able to see better at night. On the last coach (Monaco Knight 34PDD) I added the Carefree LED color lights to both the outside of the curbside living room and the patio awning. I pretty much have figured out how I can add the same LED kit to the curbside LR slideout but would also like to add an LED Kit to the power patio awning (CareFree Mirage), was wondering if anybody has already done this and could tell me how they ran the wires. Thanks in advance! Link to comment Share on other sites More sharing options...
Marine Boy Posted December 11, 2023 Share Posted December 11, 2023 If you don't have your units build sheet, I would first get it from REV. On that build sheet you will find the model/serial numbers for most of the items that were installed on your bus when built new. With the numbers of your awning, Carefree will be able to tell you what product you have. From there, Carefree will be able get you what you need including awning fabric size needed. Carefree also has video's on how to service their awnings. Link to comment Share on other sites More sharing options...
Russ R Posted December 11, 2023 Share Posted December 11, 2023 There should be a serial number on the awnings somewhere. All of mine (a 2003) have serial numbers. Most are on the inner part of the covers. If you can find the serial numbers Carefree can tell you everything about the awning, including the original material color. Link to comment Share on other sites More sharing options...
96 EVO Posted December 11, 2023 Share Posted December 11, 2023 They 'look' to me like my SOKIII's. Check this video. May give you a better idea of what you have. Link to comment Share on other sites More sharing options...
timaz996 Posted December 11, 2023 Share Posted December 11, 2023 When it came to slide out toppers I decided to go a different route and when with True Toppers. You can find YouTube videos to show them in operation. I full time in my coach and love them. 1 Link to comment Share on other sites More sharing options...
Olethehammer Posted December 13, 2023 Share Posted December 13, 2023 How do they glide over the outer flange? Link to comment Share on other sites More sharing options...
timaz996 Posted December 14, 2023 Share Posted December 14, 2023 There is a ramp built by True Toppers as part of the install. Do a YouTube search for True Topper as there are a lot of videos showing the process and how they operate. Link to comment Share on other sites More sharing options...
