Ivan K Posted April 14 Share Posted April 14 Good deal. You don't even have to use the valve if you can change the filter quickly. Since you mention a screw, you have a 2 piece shaft and yes, remove the screw and the now separated pieces. Link to comment Share on other sites More sharing options...
wamcneil Posted April 14 Share Posted April 14 And when you remove the shaft, make sure make it doesn’t leave an old o-ring way down in there where it’s hard to see… I learned that two o-rings are not better than one and would up rebuilding mine twice. Also, a new screw is very tight in a new shaft and doesn’t cut new threads easily. Mine broke and I wound up re-using the original screw. Link to comment Share on other sites More sharing options...
