ktloah Posted April 2 Share Posted April 2 good morning, our 04 Dynasty's shower door will not close anymore. Seems there is a grey plastic strip that runs the length of the door and 1/2 of it is broken preventing the door from closing. It seems this strip acts as a hinge. Not sure how to remove. Thank you all Link to comment Share on other sites More sharing options...
jacwjames Posted April 2 Share Posted April 2 I think the plastic strip acts more to keep water in the shower and/or holds the glass in place. The door is probably a male/female hinge type system where the two pieces interlock to allow the door to swing. Really only way to tell is to remove the door and see how it works. The plastic strip is probably replaceable. DK Hardware sells lots of types of hardware. https://www.dkhardware.com/ Link to comment Share on other sites More sharing options...
Tom Cherry Posted April 2 Share Posted April 2 Get the company name off the etched info on the shower door. Call them. You may have to send your pictures. That will be your best first step. Otherwise, you might have to do some “major mods” to replace with a different design. These units were made by several different companies. Some went belly up circa 2010. Others were bought out and consolidated into a larger company. if there is no “easy” DIY Fabricated fix….google and chase down the factory. For example, Shower Enclosures of America (SEA) was a major Monaco supplier and we can still get all the hardware and parts for our 15 - 18 year old assemblies…. Link to comment Share on other sites More sharing options...
Duffer51 Posted April 2 Share Posted April 2 I had the exact same issue with my 04 Dynasty shower door. On the inside of the shower there is a trim piece with a small screw at the top and the bottom, remove those and the trim piece should come off and reveal pivot piano hinge that can be replaced with one from Amazon for 10.00. Hardware Essentials 851063 Continuous Pin 24" x 1-1/4" Nickel - Door Hinges - Amazon.com Link to comment Share on other sites More sharing options...
Paul J A Posted April 2 Share Posted April 2 It is from and made by; https://www.seamerica.com/ Link to comment Share on other sites More sharing options...
Tom Cherry Posted April 2 Share Posted April 2 1 hour ago, Paul J A said: It is from and made by; https://www.seamerica.com/ Traico@seamerica.com Is the email address of their TOP Parts guy. SEA also has a “secondary” or affiliated company that distributes their parts. Google and get phone number. Call. There is (was) an option to connect to Traico. Very helpful and responsive over the years. If the enclosure in question is an SEA….high probability that parts are readily available. Link to comment Share on other sites More sharing options...
ktloah Posted April 3 Author Share Posted April 3 Thank you all for your information. I called SEA and after looking at my pics, they determined the shower door was not a SEA but KOHLER STERLING. So I called them in Wisconsin and got the usual ( no model# no parts...)we are traveling so when we stop, I will attempt to try to get the #'s from the door like Tom said. If need to, maybe replace everything with a standard piano hinge... Link to comment Share on other sites More sharing options...
ktloah Posted April 3 Author Share Posted April 3 20 hours ago, Duffer51 said: I had the exact same issue with my 04 Dynasty shower door. On the inside of the shower there is a trim piece with a small screw at the top and the bottom, remove those and the trim piece should come off and reveal pivot piano hinge that can be replaced with one from Amazon for 10.00. Hardware Essentials 851063 Continuous Pin 24" x 1-1/4" Nickel - Door Hinges - Amazon.com Hi Ron, this door seems to have a pivot point on the top and bottom of the door. I believe they call it a pivot block. Did you replace yours with the piano hinge? Link to comment Share on other sites More sharing options...
Duffer51 Posted April 3 Share Posted April 3 Here's the link to what I used Gordon Glass® Shower Door Stainless Steel Hinge Pin 5/16" Dia. and Washer for Continuous Hinge Framed Shower Enclosure - Shower Doors - Amazon.com Gordon Glass® Plastic Hinge Sleeve ONLY for Shower Doors with Continuous Hinge - 84" Long | Outside Dia.: 5/16" ; Inside Dia: 1/4" | Plastic Hinge Sleeve ONLY. | Continuous Hinge NOT Included. - Amazon.com Link to comment Share on other sites More sharing options...
