John C Posted April 12 Share Posted April 12 I need to jack up the coach and want to make sure I put my 20 ton jack stand in the right place. For the front, there is a cross metal right behind the front wheel, I am thinking put the jacks there. For the back, there is a metal straight down behind the tag axle, I am thinking put it over there, the only thing I am not sure is the metal is not completely solid. Could the experts here chip in what you think? I understand the put the jack stand right under the axle is another option, but I am thinking maybe those points are better. Link to comment Share on other sites More sharing options...
Tom Wallis Posted April 12 Share Posted April 12 For the rear the spots you've circled would be fine but I wouldn't use that cross bar you've circled for the front. It may not be heavy enough. The axle is usually about as good as it gets. Link to comment Share on other sites More sharing options...
John C Posted April 12 Author Share Posted April 12 1 minute ago, Tom Wallis said: For the rear the spots you've circled would be fine but I wouldn't use that cross bar you've circled for the front. It may not be heavy enough. The axle is usually about as good as it gets. Got it. Thank you! Link to comment Share on other sites More sharing options...
Les Hurdle Posted April 12 Share Posted April 12 Hope I'm in the right area.. I usually get it wrong. My drivers side rear hydraulic jack does not go all the way back up. Fixes/reasons please Les Link to comment Share on other sites More sharing options...
