Water Manifold
I'm not getting water to the refrigerator, all valves on the, manifold appear to be open, but the label telling what each valve controls is missing. Can someone with a 2007 DYNASTY take a picture of valve layout?  TIA
I have a 2008 Dynasty. The water line for the refrigerator is clearly visible if you remove the bottom panel on the exterior wall at the refrigerator location. You may want to see if there is water getting to the refrigerator. If so, then you likely have a defective valve in the refrigerator that will not allow water to exit.
  • 5 weeks later...
Just FYI, I finally got water to the ice maker.  What I found was the water filter in the refrigerator was broken and not depressing the valve that lets water flow to the cold water outlet and the ice maker. $57 dollars and a new filter and we have ice. Thanks for all the pointers on where to look.
