jegall Posted May 6 Share Posted May 6 My scangauge D and dash gauge both read normal temperature but keep getting code 151 thats high coolant temperature . Anyone know if more then one sensor. Link to comment Share on other sites More sharing options...
Robert U Posted May 7 Share Posted May 7 There is two sensors. One for the ECM and one for the temp gauge. BobU Link to comment Share on other sites More sharing options...
jegall Posted May 7 Author Share Posted May 7 Any idea location ? Link to comment Share on other sites More sharing options...
jacwjames Posted May 7 Share Posted May 7 (edited) I downloaded a document from Cummins Quickserve that lists all the sensors they install, it kind of shows locaiton but a little vague but Cummins uses sensors that have a wiring connector plug end. On my ISC engine is show these two for engine, one is oil temp and one is coolant. https://shop.cummins.com/SC/product/cummins-temperature-sensor-3408345/01t4N0000048cJpQAI https://www.diamonddiesel.com/oil-coolant-fuel-temperature-sensor-for-dodge-cummins-engines-alliant-power-ap63605-oem-part-s-4954905-3865346-3096153-4088750-4088751-ap63605 Monaco usually installed sensor with a wire connector, attached is a parts listing for the coolant temp on my coach, in my case it is located on top of engine on the pulley end near the alternator. This is the picture You can create an account on Quickserve, once you have an account register your engine using the SN. It is a great resource. There is also a Fault Code lookup, it will provide an overview explanation but then within the document there will be detailed troubleshooting guide. Since you are actually getting a code it is the Cummins sensor that is sensing the high temp, it sends signal to ECM. Monaco sensors report to the gauges. Control Module sensors 3408429 oil pressure sensor.pdf 1 Water Temp Sending Unit.pdf Edited May 7 by jacwjames Link to comment Share on other sites More sharing options...
Robert U Posted May 7 Share Posted May 7 On my ISC the ecm temperature sensor is located just below the thermostat which is located below water pump. Bob U Link to comment Share on other sites More sharing options...
jegall Posted June 8 Author Share Posted June 8 Follow up on my problem my scangauge D reads a 151 code the blink code on dash is one blink then seven blinks then five blinks then is repeated. I cannot find any decode for 175 , Cummins ISL 400 hp engine is a 2002 all this on a cold engine. Link to comment Share on other sites More sharing options...
jacwjames Posted June 8 Share Posted June 8 Your scan gauge should give a two part code, Unfortunately I cannot log into the Cummins Quickserve site to try and do a fault code lookup. A general search of SPN 175 shows it has to do with the oil temperature sensor but there are several causes listed, anything from shorted wire to high oil temp. But on my ISC 350 I don't have a oil temp sensor (from memory) Link to comment Share on other sites More sharing options...
