RVKnight Posted July 21, 2020 Share Posted July 21, 2020 Does anyone have any suggestions or know where I can acquire a wiring schematic for 2006 Monaco Knight. The problem I’m having is with the WelDex 3 camera system. Not getting any power or video at the CRT unit. Checked 4 wire keyed plug going into back of CRT unit and have 12v output to the plug on red fused line. Not sure what the other 3 wires are for in the plug so unsure what they should measure. Any suggestions would be appreciated. Link to comment Share on other sites More sharing options...
Onthego Posted July 21, 2020 Share Posted July 21, 2020 If I remember correctly you need a dazzle adapter to display the video on a tablet . Try doing a search on the internet ( how to use dazzle video capture ) maybe it will help you fine something that will work. Link to comment Share on other sites More sharing options...
RVKnight Posted July 21, 2020 Author Share Posted July 21, 2020 Thanks for your response. The camera system I’m referring to is the 3 safety camera (2 side 1 tear) on the unit not a video recording system. Link to comment Share on other sites More sharing options...
Onthego Posted July 21, 2020 Share Posted July 21, 2020 You can use a tablet as a video monitor at about 1/2 the cost of a 12 volt video monitor. Back a few years this was brought up on IRV2 as a replacement for the monitor. Nothing to do with a DVR. Just trying to be helpful Rich Link to comment Share on other sites More sharing options...
Doug Hoegh Posted July 21, 2020 Share Posted July 21, 2020 Contact Tim at www.rvcams.com. A fellow Monaco owner and a great guy Link to comment Share on other sites More sharing options...
RVKnight Posted July 21, 2020 Author Share Posted July 21, 2020 Thanks very helpful Link to comment Share on other sites More sharing options...
Rich Cutler Posted July 22, 2020 Share Posted July 22, 2020 I had issues as well. Two wires are the right and left switches for the side cameras. Ground. Positive you found. Cannot remember others as it was 5 yr ago. In my case they were all tagged. Check along the wires for the tags. In my case the component came loose and shorted out the main board. Had intermittent problems before because of loose connection. replacement was $400 and it never worked correctly after. Weldex switched boards and screen again, but I think the old model cameras just did not work will with the new screen. I trashed it for a Rearview Safety system. Used the old wires. Rich Cutler 06' Windsor Link to comment Share on other sites More sharing options...
RVKnight Posted July 22, 2020 Author Share Posted July 22, 2020 Thanks Rich, your response is helpful. My camera system has had intermittent problems for years too. On the advice of Doug I contacted RVCAMS and we are trying to work out a replacement or upgrade. Link to comment Share on other sites More sharing options...
Rich Cutler Posted July 22, 2020 Share Posted July 22, 2020 FYI. The Rearview Safety is now std equipment on many units. I paid $200 complete without the side camera option. I did not like that distraction vs mirrors. Color screen needed minor cutting the dashboard to fit. Link to comment Share on other sites More sharing options...
RVKnight Posted July 22, 2020 Author Share Posted July 22, 2020 Thanks, Rich. Link to comment Share on other sites More sharing options...
Steven P Posted July 26, 2020 Share Posted July 26, 2020 Garland, I have an 06 Diplomat and was recently sent this. Tim may have already sent it to you? My weldex screen went out and for troubleshooting it I plugged the rca cables into a tv and could see again, so replaced my monitor. You can try plugging in each camera to a tv to narrow down the problems. I have an intermittently working left and rear camera. Monaco Camera Wiring Diagrams.pdf Link to comment Share on other sites More sharing options...
RVKnight Posted July 26, 2020 Author Share Posted July 26, 2020 Thank this appears to be the same issue. The diagram will be very helpful. Much appreciated, Garland G 1 Link to comment Share on other sites More sharing options...
