tmw188 Posted July 8 Share Posted July 8 It’s been a good while if my memory is correct in thinking the green travel light indicator on my 2002 Windsor use to only come on when the coach was aired up and ready to travel. It is now indicating right after start up when the coach is not aired up. I have air leveling control panel and it is not on and if so it shouldn’t display. Link to comment Share on other sites More sharing options...
Solution timaz996 Posted July 8 Solution Share Posted July 8 It has been posted on this and other forms that that green light comes on when your pressure is up above 100 pounds not necessarily when the coach is up at Ride height . One of many reasons I always walk around the coach to confirm it is up at ride height. The toad is hooked up correctly slides are all in, etc. etc. etc. Link to comment Share on other sites More sharing options...
tmw188 Posted July 9 Author Share Posted July 9 Yes I do a walk around too. No it’s not aired up to 100psi. Link to comment Share on other sites More sharing options...
