isptbart Posted August 7, 2020 Share Posted August 7, 2020 When I purchased my 07 HR Scepter the dealer passed on to me a well-worn & taped up non-functional Key Fob. After contacting the previous owner, I was told 3 key Fobs were given to the dealer, two of which were unused & I ended up with only the one. The dealer denies ever having the additional fob so I'm at a dead end with him.Therefore, I'm searching for a replacement. I have been told by several suppliers my fob is out of production & no longer available. I have contacted a couple of RV salvage yards with no success thus far. Therefore, I'm reaching out to a couple of RV forums to see if I can find one. Attached is a photo of mine. Th back of the case is marked as a JLFTX4. I had to add the small bolt in the center in order to keep the two-piece fob together after removing the tape. If anyone out there is willing to part with one or can supply me with a lead for one it would be greatly appreciated! OK to contact me off-line at Itrackm @ Verizon dot net Many Thanks! Bart from VA, 07 HR 42PLQ Scepter Link to comment Share on other sites More sharing options...
Guest Cruzbill Posted August 8, 2020 Share Posted August 8, 2020 Google Tri-Mark and Essex. You need to find out who made your keyless entry; Those are two companies that supplied same to Beaver/ Monaco. Link to comment Share on other sites More sharing options...
michaelivan Posted August 8, 2020 Share Posted August 8, 2020 This is what I found that works with my 03 Windsor. https://www.ebay.com/c/2213305671 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted August 8, 2020 Share Posted August 8, 2020 2 hours ago, michaelivan said: This is what I found that works with my 03 Windsor. https://www.ebay.com/c/2213305671 Mike , I have a 03 Windsor too , so this remote sounds like what I'm looking for . The ebay site says "Easily copy your existing fixed code remote controls Can copy the function face-to-face without a duplicator With a groove design on the front for better grip Green LED light" Can you elaborate on how this copying is done ? thanks in advance Link to comment Share on other sites More sharing options...
michaelivan Posted August 8, 2020 Share Posted August 8, 2020 Ray, Do you still have a functioning remote? If so, I just followed the instructions that I downloaded and it worked. I have attached a copy of the manual. Mine has been working fine for over a year. Originally purchased to replace a sporadically working remote and to help my wife who couldn't master the keyless entry and she loves it. Remocon programming.pdf Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted August 8, 2020 Share Posted August 8, 2020 Thank you Mike , yes I still have one working remote should have mentioned that . I know it is living on borrowed time so I'll order 1 or 2 and save the old one it's being held together with tape . Link to comment Share on other sites More sharing options...
isptbart Posted August 8, 2020 Author Share Posted August 8, 2020 Thanks to you all for this suggestion! My key less entry fob remote system is made by Tri-Mark. I will followup on this lead! Bart from VA! 6 hours ago, michaelivan said: This is what I found that works with my 03 Windsor. https://www.ebay.com/c/2213305671 Michael , Is your fob system by Tri-Mark? Thanks! Bart Link to comment Share on other sites More sharing options...
michaelivan Posted August 8, 2020 Share Posted August 8, 2020 Bart, Mine has the Essex system. Link to comment Share on other sites More sharing options...
vito.a Posted August 8, 2020 Share Posted August 8, 2020 (edited) Bart, I recognize your old 2007 remote as the early Trimark system which you already found is out of production. However, you can purchase an aftermarket programmable remote for it. I purchased a new Remocon RMC-105 universal remote fob from:https://www.cruisingforremotes.com/They preset the frequency (on the back of the old remote) and I programmed it to my original Trimark RF receiver using the steps in post #21 in the link below. It locks, unlocks, and also lights the entry lights.The FCC ID is: JLFTX4 310mhz Read post # 22. https://www.irv2.com/forums/f115/help-with-trimark-key-fob-programming-324146-2.html Let me know if you have any more questions? Edited August 8, 2020 by vito.a Link to comment Share on other sites More sharing options...
isptbart Posted August 9, 2020 Author Share Posted August 9, 2020 1 hour ago, vito.a said: Bart, I recognize your old 2007 remote as the early Trimark system which you already found is out of production. However, you can purchase an aftermarket programmable remote for it. I purchased a new Remocon RMC-105 universal remote fob from:https://www.cruisingforremotes.com/They preset the frequency (on the back of the old remote) and I programmed it to my original Trimark RF receiver using the steps in post #21 in the link below. It locks, unlocks, and also lights the entry lights.The FCC ID is: JLFTX4 310mhz Read post # 22. https://www.irv2.com/forums/f115/help-with-trimark-key-fob-programming-324146-2.html Let me know if you have any more questions? Vito - many thanks for the info! I will certainly check this recommendation out! Bart from VA Vito - many thanks for the info! I will certainly check this recommendation out! Bart from VA 4 hours ago, michaelivan said: Bart, Mine has the Essex system. Michael - OK, thanks! Bart from VA Link to comment Share on other sites More sharing options...
