wamcneil Posted August 10, 2020 Share Posted August 10, 2020 Hi all, I've google'd till I'm blue in the face and I can't find a spec sheet that lists the CCC2 10-button dimensions. The only dimensions I can find are the outer BOX dimensions, Can somebody tell me the actual width of the 10-button CCC2? Thanks, Walter Link to comment Share on other sites More sharing options...
John Haggard Posted August 10, 2020 Share Posted August 10, 2020 3×6 Link to comment Share on other sites More sharing options...
wamcneil Posted August 10, 2020 Author Share Posted August 10, 2020 (edited) Thanks John. That picture is perfect. That's the exact spot I'm concerned about! Looks like it can coexist with the fan thermostat. Cheers, Walter Edited August 10, 2020 by wamcneil Link to comment Share on other sites More sharing options...
John Haggard Posted August 10, 2020 Share Posted August 10, 2020 39 minutes ago, wamcneil said: Thanks John. That picture is perfect. That's the exact spot I'm concerned about! Looks like it can coexist with the fan thermostat. Cheers, Walter I drilled a two inch hole Fit perfectly 3x6 demminsion for new 10 button Link to comment Share on other sites More sharing options...
