bhsl8 Posted September 25, 2020 Share Posted September 25, 2020 I need new struts for my bay door with the sliding tray. There is no listing for pounds on the two that failed. The length is 19 1/2 inches. Where might I snag that info? Thanks Brouck Sleight 2002 Dynasty 2020 Explorer ST Link to comment Share on other sites More sharing options...
miacasa_2000 Posted September 26, 2020 Share Posted September 26, 2020 Did you look close at them for their part # on them. All of mine are lift-o-mat except my large bay door on D.S. so I assumed the previous owner had replaced it. Actually seamed like the whole door was replaced. Anyway I have a 2003 Dynasty on my P.S. the Lift-O-mat is 1670EH 0590N The D.S. is Supa C16-08260 which is 60 lb. which they list as a 20" Roy Link to comment Share on other sites More sharing options...
jacwjames Posted September 26, 2020 Share Posted September 26, 2020 Attached is the parts page for my Windsor, which may or may not be the same as your coach. It shows 80, 60, and 40 lbs struts depending on door size. I have ordered and replaced the larger ones. Not sure on the engine access door, it takes 2 which may be the 80 lb struts. 1 Baggage Door Struts.pdf Link to comment Share on other sites More sharing options...
