CapnDean Posted November 2, 2020 Share Posted November 2, 2020 Greetings; New to me 2008 Camelot 42PDQ. I am about to change the fuel filters. I am well versed in this kind of operation, but I do not know if the 08 Cummins ISL engine has an electric lift pump. I will likely fill the filters before I install them when I am at home. However, Having had to change filters on the road on several occasions.... I don't plan on carrying a gallon of diesel to prime with. Will this engine prime itself with the repeated cycle of the key? If it wont, I may plumb in a 12V inline priming pump. Link to comment Share on other sites More sharing options...
David White Posted November 2, 2020 Share Posted November 2, 2020 I think your owners manual will cover this, but if you are not prefilling the filters, the electric lift pump will fill them. With the ignition is switched on, the pump will run for a few seconds (you should hear this). You will need to turn the ignition off and on for several cycles, but the filters will eventually fill. Don’t just try to start, but use the pump cycles to fill before attempting start. Link to comment Share on other sites More sharing options...
Ray Davis Posted November 2, 2020 Share Posted November 2, 2020 I change the filters one at a time , sometime I prefill them but either way I get the engine running smooth before moving on to the second filter . That's just me others may change both but if I have a problem I will know which filter is the culprit . 1 Link to comment Share on other sites More sharing options...
Dennis H Posted November 2, 2020 Share Posted November 2, 2020 Mine has a button to push that fills them before starting the engine. If you have a manual check that. If not, go to the manual section here and pull it up....Dennis Link to comment Share on other sites More sharing options...
