jimmcpheters Posted November 27, 2020 Share Posted November 27, 2020 Quick update, installed new latching controller, all is well. It also controls the tank test switch on the monitor panel in the hallway. Thanks again to all responders for sharing their knowledge. Jim McPheters 08 dip Link to comment Share on other sites More sharing options...
Dr4Film Posted November 27, 2020 Share Posted November 27, 2020 Glad you were able to solve your problem with a new latching controller. I have had difficulties at times getting the latching controller to activate. I now carry a spare so when it does fail completely I won't be without water. Link to comment Share on other sites More sharing options...
Timothy Posted November 28, 2020 Share Posted November 28, 2020 Where are these normally located. Link to comment Share on other sites More sharing options...
Dr4Film Posted November 28, 2020 Share Posted November 28, 2020 Well based on history they could be located anywhere but should be located fairly close to the water pump itself. At least mine is along with fuses and relays associated with the water pump circuit. Link to comment Share on other sites More sharing options...
jimmcpheters Posted November 28, 2020 Author Share Posted November 28, 2020 Mine was in the service bay, behind the big panel, on the right hand wall. Jim McPheters Link to comment Share on other sites More sharing options...
b_faster Posted November 28, 2020 Share Posted November 28, 2020 My relay is mounted in the cabinet behind the slide controls, inverter control, and tank gauges. Link to comment Share on other sites More sharing options...
Timothy Posted November 29, 2020 Share Posted November 29, 2020 Thanks all. I'll look. Link to comment Share on other sites More sharing options...
