Jeff H Posted December 12, 2020 Share Posted December 12, 2020 Hello I have a friend with a boat that wants to install a generator and an inverter/charger. He has asked me how the system works and I am not entirely sure. So is there a diagram out there that would show how the Shore power/ Gennie/ inverter are wired for a 2006 Diplomat PDQ? I looked in the downloads section but I could not find one. Thank you Link to comment Share on other sites More sharing options...
jacwjames Posted December 12, 2020 Share Posted December 12, 2020 (edited) I just looked at the manual for Xantrex inverter, there are installation instructions that include a decent wiring schematic showing the entire system including the generator, transfer switch and shore power along with the 120 volt circuit panels. I'd suggest you look at the make/model inverter you are looking to install and see what it has on installation instructions. Edited December 12, 2020 by jacwjames Link to comment Share on other sites More sharing options...
Jeff H Posted December 12, 2020 Author Share Posted December 12, 2020 Will do Thanks Link to comment Share on other sites More sharing options...
Scotty Hutto Posted December 13, 2020 Share Posted December 13, 2020 Here is the 120vac from a 2006 Dip. I didn’t realize this wasn’t in the files section. @Frank McElroy can you add it? 2006 Monaco Diplomat 120VAC Diagram.pdf Link to comment Share on other sites More sharing options...
Frank McElroy Posted December 13, 2020 Share Posted December 13, 2020 Thanks Scotty - I added the 120VAC wiring diagram to the existing 2006 Diplomat 12VDC wiring diagram file. That way, both the 12VDC and 120VAC wiring diagrams are under the 2006 Diplomat wiring diagrams. Link to comment Share on other sites More sharing options...
Jeff H Posted December 13, 2020 Author Share Posted December 13, 2020 11 hours ago, Scotty Hutto said: Here is the 120vac from a 2006 Dip. I didn’t realize this wasn’t in the files section. @Frank McElroy can you add it? 2006 Monaco Diplomat 120VAC Diagram.pdf 104.16 kB · 8 downloads Thank You Scotty. The questions made me realize I wasn't too familiar with the system and I shoud change that. Link to comment Share on other sites More sharing options...
