Patrick R Posted January 6, 2021 Posted January 6, 2021 I have a 2001 Diplomat LE. My question is about the assist handle by the door. Is this handle supposed to light up on this model?
Guest tcbrow Posted January 6, 2021 Posted January 6, 2021 I've heard that they may. I've never seen one light up. I took the chrome ends off of mine and there are no lights under there.
Patrick R Posted January 6, 2021 Author Posted January 6, 2021 Thank you. I suspect there are not any in mine either.
HarleyR Posted January 7, 2021 Posted January 7, 2021 My acrylic handle is illuminated by a single led bulb in a reflector inside the chrome trim cap at the bottom end. Perhaps it's something you could retrofit if the factory didn't install one. 1
Dennis H Posted January 7, 2021 Posted January 7, 2021 Patrick, easiest way to tell is to remove the handle. There's only a few screws and it comes right off. If there are two wires coming off it, then you should have a light. If it doesn't work, while you've got it off you can fix it. The wires go into the cavity under the passenger's cup holder....Dennis
