bborc2005 Posted February 14, 2021 Share Posted February 14, 2021 Is it possible to replace one of the relays on the intellitec board? Last summer the rear air lost power from the board while I was on 50amp service. There was no power coming from the relay to the rear air. Everything works otherwise. It is a model 760. Link to comment Share on other sites More sharing options...
DavidL Posted February 14, 2021 Share Posted February 14, 2021 anything is possible if you have the knowledge and tools 🙂 If the relay is simply soldered to a PCB board, then unsolder it and clean the board and solder a new one on. How do you know it's the relay that is bad? Making that determination is the harder part. replacing it is the easy part. Link to comment Share on other sites More sharing options...
pwhittle Posted February 15, 2021 Share Posted February 15, 2021 I have replaced relays on various boards. Some are tricky to unsolder, but with the right tools, not too bad. Paul Link to comment Share on other sites More sharing options...
bborc2005 Posted February 15, 2021 Author Share Posted February 15, 2021 Well I just thought that was the cheaper way to try a new relay. other wise its buy a new board. being that everything else is working and no faults from the board it is probably a bad relay. Link to comment Share on other sites More sharing options...
codelld Posted February 16, 2021 Share Posted February 16, 2021 When you remove the board to replace the relay, check the printed circuit runs leading to the relay. I have had the AC go inop and when I went to replace the relay the high current of the AC had caused the solder connections on the relay to fail and burn the copper runs. Link to comment Share on other sites More sharing options...
bborc2005 Posted February 16, 2021 Author Share Posted February 16, 2021 Will do thanks Link to comment Share on other sites More sharing options...
