Bob Stevens Posted March 15, 2021 Share Posted March 15, 2021 (edited) Right leveler will not go down. Left and front work fine but right is in the up position(thank God) and won’t budge. Hydraulics make a weird noise when we try to put the right down only. 1998 Monaco Windsor no slides 32’. i’ve tried “coaxing” it with a hammer in case it’s rusted. I also took off the springs and foot. Edited March 15, 2021 by Bob Stevens Link to comment Share on other sites More sharing options...
bobdinsmore Posted March 15, 2021 Share Posted March 15, 2021 I assume you have RVA Jacks in which case you may want to try opening up the t-handle on the hydraulic pump for that jack a little and try again. There may be a restriction in that valve. Link to comment Share on other sites More sharing options...
Bob Stevens Posted March 15, 2021 Author Share Posted March 15, 2021 I didn’t see a T handle, but I’ll look. Link to comment Share on other sites More sharing options...
RVSSNAKE Posted March 15, 2021 Share Posted March 15, 2021 Is the sound like a screeching metal on metal sound when going down? If you have never replaced it, that is likely your hydraulic motor. I just replaced our last spring. Not a difficult task at all. This was the one for our 2000 Diplomat. Yours may be different. https://www.rvajack.com/RVA-MTR-01-RVA-Pump-Motor-for-16A-22.5-32-Systems Alan with their support was very helpful. Alan (Support) <help@rvajack.com> Link to comment Share on other sites More sharing options...
Bob Stevens Posted March 18, 2021 Author Share Posted March 18, 2021 Found the problem. The right coil on the pump wasn’t working. thanks for trying to help. Link to comment Share on other sites More sharing options...
