Steve Hepfer Posted April 15, 2021 Posted April 15, 2021 I have a 2008 Monaco Diplomat 36PDQ. I recently discovered that I don't have any tail lights. Can anyone help me locate the correct fuse or relay for the taillights? I have checked the bulbs and the flashers work so I don't think it is a bulb issue and I pulled the bulbs to check the filament which is fine. I have checked all 3 fuse boxes and cannot find any thing marked as "Tail Light". THX
klcdenver Posted April 15, 2021 Posted April 15, 2021 Try looking in your owners manual, probably section 9 if the same as mine. I believe they are labeled as marker lights.
Scott 61 Posted April 15, 2021 Posted April 15, 2021 My tail light fuses are in the last compartment on the passenger side
Steve Hepfer Posted April 15, 2021 Author Posted April 15, 2021 Are they marked as TAIL LIGHTS? I have looked there also and found none marked specifically as Tail Lights
Scott 61 Posted April 15, 2021 Posted April 15, 2021 If it's not their check the front run box not at my motorhome right now so I can't look sorry
DJR1SR Posted April 15, 2021 Posted April 15, 2021 I had the same problem, none of the running lights/ Marker lights worked. Headlights, brake and turn signal lights worked fine. The drivers side front compartment has a series of boxes with fuses and relays. My panel was the lower right side. Squeeze the lock down clamps to pull the cover off. Look for the fuse labeled marker lights and check to see if the fuse is good, replace if needed. I had a blown fuse, replaced it and all is well. This is just one man's opinion and I hope this helps.
Steve Hepfer Posted April 15, 2021 Author Posted April 15, 2021 51 minutes ago, klcdenver said: Try looking in your owners manual, probably section 9 if the same as mine. I believe they are labeled as marker lights. I looked at my manual and the "Marker Lights" are fuse F65 which I changed to 10amp fuse and still no tail lights 19 minutes ago, DJR1SR said: I had the same problem, none of the running lights/ Marker lights worked. Headlights, brake and turn signal lights worked fine. The drivers side front compartment has a series of boxes with fuses and relays. My panel was the lower right side. Squeeze the lock down clamps to pull the cover off. Look for the fuse labeled marker lights and check to see if the fuse is good, replace if needed. I had a blown fuse, replaced it and all is well. This is just one man's opinion and I hope this helps. I have running lights. It's just the tail lights. I replaced the fuse labeled marker lights and still nothing
klcdenver Posted April 16, 2021 Posted April 16, 2021 In my 2007 Diplomat I have Marker Fuses in 2 different locations. See Attached. I would get a test light or fuse tester and check fuse in place because it may be blowing as soon as you replace it.
DJR1SR Posted April 16, 2021 Posted April 16, 2021 39 minutes ago, Steve Hepfer said: I looked at my manual and the "Marker Lights" are fuse F65 which I changed to 10amp fuse and still no tail lights I have running lights. It's just the tail lights. I replaced the fuse labeled marker lights and still nothing Actually now thinking further there were 2 fuses in the same forward compartment, one in the big center box and the other in the lower right box as I described earlier. Good luck.
klcdenver Posted April 16, 2021 Posted April 16, 2021 It just came back to me but older cars like 1970's models had the tail lights on the dash panel fuse. It was this way so if at night you didn't have dash lights you knew your tail lights were out also. Not sure if if Monaco is set up this way or not but I would check.
Steve Hepfer Posted April 16, 2021 Author Posted April 16, 2021 14 hours ago, Scott 61 said: My tail light fuses are in the last compartment on the passenger side Thanks Scott. You nailed it. The fuse wasn't in either of the two boxes in the front roadside compartment. There was indeed a 3rd panel box in the rear passenger side compartment. A quick fuse replacement and no good to go. Thanks to ALL for assisting.
