powersltc Posted May 15, 2021 Share Posted May 15, 2021 Ron P. 2004 Monaco Executive Question: Has anyone upgraded their A/C units to the remote control quieter units. If so, what do you think? Link to comment Share on other sites More sharing options...
Ktbt21 Posted May 15, 2021 Share Posted May 15, 2021 No but I did install the Wacko silencer on my unit. Qiuted it down such taht you almost have to listen for it to hear it run. Link to comment Share on other sites More sharing options...
Joelsheriff Posted May 15, 2021 Share Posted May 15, 2021 What's the wacko silencer? Please and in which unit does it work or a link to the product. How difficult was the install and is it inside or roof top install. TIA Link to comment Share on other sites More sharing options...
Ktbt21 Posted May 15, 2021 Share Posted May 15, 2021 https://wackoproducts.com/ provides the silencer for coleman and duo-therm ac units. I used the duo-therm on mine. It took about a hour b/c I was taking my time. Dometic, sorry Link to comment Share on other sites More sharing options...
rpasetto Posted May 15, 2021 Share Posted May 15, 2021 (edited) Has anyone installed that WACKO unit on a coach with the big swing down board which covers the inlets? Edited May 16, 2021 by rpasetto Link to comment Share on other sites More sharing options...
Howard Posted May 15, 2021 Share Posted May 15, 2021 I replaced my rear duo therm on my 2004 Diplomat with the Houghton 15 btu with the heat pump and remote controlled (right around $1150 delivered). I bypassed the rear station on my thermostat, and have the heater hooked up to the front station that still has the duo therm unit. This unit works great, and is super quiet. I live in the high desert area of SoCal, and we recently had temps in the low to mid 90's. I just ran this unit to see how it does, and it kept my entire RV at a comfortable temperature with it set at 74 deg. This draws about 3/4 of the load that the Duo therm does. So far I am happy with it. I will be spending several months this summer along the coast, so I will see how it does with the heat and humidity. If it does well, I will probably the front unit with one also. It's not quite a convienient as having everything run off from one thermostat (These will not work with a wall mounted thermostat), but I can deal with that issue. 1 Link to comment Share on other sites More sharing options...
windsorbill06 Posted June 19, 2021 Share Posted June 19, 2021 On 5/15/2021 at 4:57 PM, Howard said: I replaced my rear duo therm on my 2004 Diplomat with the Houghton 15 btu with the heat pump and remote controlled (right around $1150 delivered). I bypassed the rear station on my thermostat, and have the heater hooked up to the front station that still has the duo therm unit. This unit works great, and is super quiet. I live in the high desert area of SoCal, and we recently had temps in the low to mid 90's. I just ran this unit to see how it does, and it kept my entire RV at a comfortable temperature with it set at 74 deg. This draws about 3/4 of the load that the Duo therm does. So far I am happy with it. I will be spending several months this summer along the coast, so I will see how it does with the heat and humidity. If it does well, I will probably the front unit with one also. It's not quite a convienient as having everything run off from one thermostat (These will not work with a wall mounted thermostat), but I can deal with that issue. sure would love to hear a review on this particular a/c unit now that you've had it awhile. Are they as quiet as they claim? Link to comment Share on other sites More sharing options...
