Banging noise in steering column
My 04 Windsor has developed a knocking and  sound and feel in the steering column just under the steering wheel. Has anyone else had this issue? My model is a 40 DST.
Any help would be much appreciated.
There could be an issue in the front axle and steering linkage, you would feel it all the way up the steering column.
Also, there are 3 zerk fittings that require greasing, all are not easy to get to.  There are two accessible from underneath, a slip joint and U-joint.  The third one you have to remove the plastic cover from the base of the steering column, there is a U-joint there also.
