Walker Posted July 2, 2021 Share Posted July 2, 2021 I installed two new a/c units and a new ccc2 thermostat. Everything works correctly. When I change zones (I have two), I have to scroll through zone 3 and 4 (non-existent) to get back to zone 1. On zone 3 and 4 it says E1-makes sense since they don't exist. How do I program zone 3 and 4 out? Thanks Link to comment Share on other sites More sharing options...
Carney Posted July 2, 2021 Share Posted July 2, 2021 Hey Matt, I am replacing both Heat Pumps and the CCC with the CCC2, was wondering if you had the CCC. If so did the wires all work on the CCC2? Thanks. Dave C. 2006 Monaco Windsor Link to comment Share on other sites More sharing options...
Walker Posted July 2, 2021 Author Share Posted July 2, 2021 Carney, everything was plug and play for me. I replaced old dometic(penguins with 5 button ccc) with new dometic(blizzards with ccc2). I have two heatpumps, and two furnaces, but no aquahot. Your new heat pumps must have the new style controllers to be compatible with the ccc2. If you have any questions, I'll do my best to help. I installed the pumps, hooked up the wiring, plugged the communication cables in and flipped the dip switches. It was really that easy. Link to comment Share on other sites More sharing options...
hitechpete Posted July 2, 2021 Share Posted July 2, 2021 See the attached photo of the CCC2 manual. 1 Link to comment Share on other sites More sharing options...
Walker Posted July 2, 2021 Author Share Posted July 2, 2021 Pete thanks. I am going to do that today. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 2, 2021 Share Posted July 2, 2021 Two important steps when doing a new install is to set the DIP Switch configuration correctly on the control board inside each new AC followed by a system reset on the CCC-II thermostat. Link to comment Share on other sites More sharing options...
Carney Posted July 2, 2021 Share Posted July 2, 2021 Matt, Thanks for the information, I just ordered the new heat pumps, and the CCC2 thermostat. Hopefully they will ship soon, your info will help with the install. Thanks again. Carney 2006 Windsor Link to comment Share on other sites More sharing options...
hitechpete Posted July 2, 2021 Share Posted July 2, 2021 Penguin 2 installation and dip switch configuration. Link to comment Share on other sites More sharing options...
eddie4ne Posted July 3, 2021 Share Posted July 3, 2021 Learned the hard way about the need to set the dip switches, turned on the HP in 30 degree temperature and since the Furnace dip switch was not flipped, we blew the Freon from a relatively new install. Hard lesson learned! Had to replace the AC/HP again!!! Link to comment Share on other sites More sharing options...
Dr4Film Posted July 3, 2021 Share Posted July 3, 2021 33 minutes ago, eddie4ne said: Learned the hard way about the need to set the dip switches, turned on the HP in 30 degree temperature and since the Furnace dip switch was not flipped, we blew the Freon from a relatively new install. Hard lesson learned! Had to replace the AC/HP again!!! We've all had those "hard" lessons in one form or another. Mine was leaving my motorcycle unused for a 6 month length of time during one season with ethanol fuel inside. Now I will only burn non-ethanol fuel PLUS I always use SeaFoam Fuel Stabilizer in the fuel too. That lesson cost me a fuel pump and two new fuel injectors plus fuel lines and fuel tank clean-out along with ancillary items plus labor, over $2000. Link to comment Share on other sites More sharing options...
