4rickyg Posted July 10, 2021 Share Posted July 10, 2021 05 Navigator, central vac not working. No triped breakers,any other ideas I should check? Never had a problem with it before. Thanks Rick Link to comment Share on other sites More sharing options...
Dr4Film Posted July 10, 2021 Share Posted July 10, 2021 (edited) First thing is to check whether the motor is getting power to it or not. Once you know that, then you can direct your attention to either before the motor or the motor itself. Time to get your trusty DVOM out which every coach owner should have and know how to use it. Edited July 10, 2021 by Dr4Film Link to comment Share on other sites More sharing options...
redstickbill Posted July 10, 2021 Share Posted July 10, 2021 In my 07 Dynasty the two contact screws in the wall socket have loosened and do not make good contact with the metal collar on the hose and the vac will not run. When I make good contact between the screws and thaehose collar the vac runs as it should. for me this is a "sometime in the future repair". Bill B 07 Dynasty Link to comment Share on other sites More sharing options...
4rickyg Posted July 10, 2021 Author Share Posted July 10, 2021 Vac is working. Forgot I unplugged it in the basement a few weeks ago!! Thanks for the replies. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 10, 2021 Share Posted July 10, 2021 1 Link to comment Share on other sites More sharing options...
