Brett63 Posted August 1, 2021 Share Posted August 1, 2021 Where do they typically hide the AGS module for an 09 Sig? Next question, I am running my AGS (well trying to) and have set to start on VDC set at 11v. the Gen come on, runs prescribed time and turns off, a couple minutes later it starts back up and does the same. When I go to Tech on the Magnum remote on within the AGS I am only reading 6.4v which is the reason it constantly thinks it is below voltage. So why am I only showing 6.4v coming in? Link to comment Share on other sites More sharing options...
Hypoxia Posted August 1, 2021 Share Posted August 1, 2021 Mine is right beside the Magnum Inverter Charger. Which model AGS and Charger? 1 Link to comment Share on other sites More sharing options...
Brett63 Posted August 1, 2021 Author Share Posted August 1, 2021 49 minutes ago, Hypoxia said: Mine is right beside the Magnum Inverter Charger. Which model AGS and Charger? Magnum 2812 and the Magnum MEC-RC I need to change the remote out for the MEC-ARC just so I can have a bit more tunability. But unless I can figure out why I only have 6.4v it won't matter which remote I have. Link to comment Share on other sites More sharing options...
tmw188 Posted August 1, 2021 Share Posted August 1, 2021 Just a thought but sounds like it’s only reading one house battery? Link to comment Share on other sites More sharing options...
Brett63 Posted August 1, 2021 Author Share Posted August 1, 2021 35 minutes ago, tmw188 said: Just a thought but sounds like it’s only reading one house battery? But I have 12v house batts....lol Link to comment Share on other sites More sharing options...
Hypoxia Posted August 2, 2021 Share Posted August 2, 2021 Do you have a voltmeter, VOM? I normally remove the remote and hook it up at the inverter with a different data wire, frequently the wire is pinched somewhere. Call Magnum Tech support. 1 Link to comment Share on other sites More sharing options...
