tmw188 Posted September 1, 2021 Share Posted September 1, 2021 Ok this is the last indicator light that didn’t work. But I have to ask about it’s function. Is this suppose to illuminate when the switch is turned on or when the burner for the water htr fires up. I found it not wired to the switch and moved it so it would come on when the switch was on. I got to thinking a few days later maybe it’s not for the switch actually but maybe for when the burner comes on, or the gas valve opens? 02 Windsor Link to comment Share on other sites More sharing options...
Dr4Film Posted September 1, 2021 Share Posted September 1, 2021 (edited) The indicator light is to notify you when the burner lights up then it is supposed to go off unless the burner defaults and does not light up after three attempts. That information should be in the operators manual. OPERATING INSTRUCTIONS 1. STOP! Read the safety information provided.2. Turn off all electric power to the appliance.3. Turn “OFF” gas supply.4. Wait five minutes for gas to clear the area. If you smell gas then STOP! Follow instructions in item B of the SAFETY INFORMATION. If you don’t smell gas, go to next step.5. Turn “ON” gas supply.6. Turn on electrical power to the appliance.7. Locate the switch plate that operates the water heater which is somewhere inside the RV and may be similar to the ones shown in Figure 11A and 11B. Your switch may have a different appearance. 8. Once the switch is located and depending on which switch plate; Press the rocker switch marked “GAS”, or the plain rocker switch, or your switch so that it is in the “ON” position. If the burner does not light, the system will automatically attempt ignition two more times before going into lock-out. NOTE: Each ignition cycle will have a 15 second purge before spark cycle, the red “RESET” light on the switch plate will be illuminated during the 15 second purge and turn off during the spark cycle. If the red “RESET” light remains illuminated after the 15 second purge AND the system has attempted ignition three times, the system is in lockout.9. If lockout occurs before main burner lights, the red “RESET” light on the switch plate remains illuminated to indicate ignition did not occur. To reset the system and attempt ignition again, press the rocker switch marked “GAS”, or the plain rocker switch, or your switch so that it is in the “OFF” position and wait five seconds before returning the switch to the “ON” position. The first start-up of the water heater may require several ignition cycles before all the air is purged from the gas lines.10. If the burner will not ignite and remain on, the following items should be checked before calling a service person: A. Confirm if the switch marked “GAS”, or the plain rocker switch, or your switch is in the “OFF” position. B. Confirm if the Gas supply to the water heater is turned off or empty. C. Confirm if the Reset button on ECO is tripped. (see Figure 12)The reset button(s) are not visible as they are behind the cover that indicates “PUSH TO RESET”. The 12V DC ECO Switch & T-Stat is under the rubber grommet identified as “A” in the figure and the 120V electric element ECO Switch & T-Stat is under the rubber grommet identified as “B". These are the reset button(s) that would be visible if the cover from Figure 12 were removed. 11. If burner fails to light, call a Suburban Service Center or a local RV service agency Edited September 1, 2021 by Dr4Film 1 Link to comment Share on other sites More sharing options...
tmw188 Posted September 1, 2021 Author Share Posted September 1, 2021 Yeah thanks Richard! I thought that might of been the case. I’ll have to check it again for the correct operation. Link to comment Share on other sites More sharing options...
