Skipjack Posted September 20, 2021 Share Posted September 20, 2021 Should my ABS light on my instrument panel illuminate when I first turn on my ignition?. All my other dash indicator lights do, but my ABS does not. (HR 2003 Roadmaster Chassis R4R) Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 20, 2021 Share Posted September 20, 2021 Yes. That is to let you know that those lights are working, hooked up to what generates the light. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Skipjack Posted September 20, 2021 Author Share Posted September 20, 2021 Thanks The ABS light as well? I have had my coach for a couple of years and never thought about it. I have had some recent overheating in my front rotors/calipers, and it made me think about the ABS system Link to comment Share on other sites More sharing options...
Ivan K Posted September 20, 2021 Share Posted September 20, 2021 Yes, ABS light should come on for couple seconds or so while running self test. May want to check the bulb. Link to comment Share on other sites More sharing options...
PeterSchweizer Posted September 20, 2021 Share Posted September 20, 2021 I am not sure if when you turn on ignition switch if it actually does a "systems check"?. Typically it was a way to check that the indicators light bulb did in fact turn on n was not burned out. Link to comment Share on other sites More sharing options...
Ivan K Posted September 20, 2021 Share Posted September 20, 2021 Yeah, appears to be a bulb and ABS malfunction check. Either way, the light should come on. Also may want to check ABS related fuses, I've got 3 in the ignition fuse section of FRB. From my Bendix manual: ABS Indicator Lamp This lamp is the primary indicator of ABS system condition. Under normal conditions, the ABS lamp lights steadily for a two-second bulb-check whenever the switched ignition is ON. The ABS lamp turns OFF after the bulb-check if there are no ABS malfunctions present. If the indicator remains ON, after the bulb-check, or lights during vehicle operation, it indicates the ABS requires service. Link to comment Share on other sites More sharing options...
Skipjack Posted September 20, 2021 Author Share Posted September 20, 2021 Thanks a bunch guys. That is what I expected. I did have a couple of the relays go bad on me as well in the Monoco 3 box up front. (One was related to the IGN, and none of the gauges would work) I just found another relay box at the rear of the coach (Monoco 4) and it contains relays and fuses for the ABS. I think I am going to check this out thanks again Link to comment Share on other sites More sharing options...
