vanwill52 Posted October 2, 2021 Posted October 2, 2021 Once again trying to help a friend with a problem remotely. He is located in FL, several hundred miles from me. I do not have access to his wiring diagrams.He has total loss of power to his instrument panel and AC blower. Speedo, tach, and all instruments go dead, but coach continues to drive OK. On my 2000 Dynasty, when that happened to me, it was a single contactor in the FRB. It looked like an old Ford starter relay. I could tap it lightly with a screwdriver handle and all power would be restored. I replaced the contactor and never had another problem.His coach is much newer than mine and has a multitude of small relays on a printed circuit board, and nothing that resembles my layout. I’m assuming there is one relay or contactor that provides power to the dash and AC blower. I tend to doubt it’s one of those small Bosch-type relays.We replaced all his house batteries with AGM’s before our last trip together and had no issues. His engine will start normally.Has anyone ever dealt with this same problem?
Skipjack Posted October 2, 2021 Posted October 2, 2021 I had the same thing on my 2003 HR Neptune. ended up finding a bad relay in one of the Monoco relay boxes. There is one that brings on power to the dash. I went ahead and replaced them all.
vanwill52 Posted October 2, 2021 Author Posted October 2, 2021 Thanks, Skipjack. I'll have him look. Are these in the FRB?
Brett63 Posted October 2, 2021 Posted October 2, 2021 5 hours ago, vanwill52 said: Once again trying to help a friend with a problem remotely. He is located in FL, several hundred miles from me. I do not have access to his wiring diagrams.He has total loss of power to his instrument panel and AC blower. Speedo, tach, and all instruments go dead, but coach continues to drive OK. On my 2000 Dynasty, when that happened to me, it was a single contactor in the FRB. It looked like an old Ford starter relay. I could tap it lightly with a screwdriver handle and all power would be restored. I replaced the contactor and never had another problem.His coach is much newer than mine and has a multitude of small relays on a printed circuit board, and nothing that resembles my layout. I’m assuming there is one relay or contactor that provides power to the dash and AC blower. I tend to doubt it’s one of those small Bosch-type relays.We replaced all his house batteries with AGM’s before our last trip together and had no issues. His engine will start normally.Has anyone ever dealt with this same problem? Would help to know what coach your friend has.
vanwill52 Posted October 2, 2021 Author Posted October 2, 2021 It's in the TITLE of the post. 2011 Camelot. Thanks.
vanwill52 Posted October 7, 2021 Author Posted October 7, 2021 (edited) 2011 Camelot. It is the title of the post. Edited October 7, 2021 by vanwill52 delete--redundant
dandick66 Posted October 8, 2021 Posted October 8, 2021 Not sure if this will help or not. On my 2012 Diplomat, F29 is the fuse for the dash A/C. I’ve attached photos and you can see the relay for the affected circuit, too (VCN). There probably isn’t a lot of difference between your friend’s 2011 and my 2012 . Although it’s not specifically listed, it’s possible that the relay and /or fuse is tied into the dash power. I hope this helps. Dan D, 2012 Diplomat
